Question about Nikon D300 Body Only Digital Camera
I have a 2GB flash card and the the display panel states Full. I have only taken 500 pictues. Is this possible?
  • 291 Answers
Depending on what your resolution is set to, this is certainly possible. If you are set to take both RAW and JPG, then you will probably only get 300 or so with a 2GB card. If you use JPG Large, you would probably be up to 500 or so.
If you're set at a low resolution and you only get 500 on a 2GB card, you may have some other data on the card. Check it in a PC and see if there's anything else on it. If you're sure you have all the data from it you need, then format it in the PC and then put it back in the camera.
Posted on Sep 28, 2009
Ive used my card in my video camera and my digital camera and somehow it got locked.. how do i unlock my card?
Check if you have the tiny lock on either left or right side panel of the SD card. Check if it is slid to lock state.
Good luck.
Jun 19, 2011 | SanDisk 2GB microSD Memory Card
New 4G memory card states full have re-formatted but still shows full. Have tried a 2G card but that is ok to use any ideas please
Your new 4GB card is an SDHC card. The S700 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with cards 2GB and smaller.
Jan 10, 2011 | Samsung Digimax S700 Digital Camera
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
I have a Casio EXILIM EX-S10 "Memory Full" Error
Firstly, charge your battery fully. This should solve the switching off. It sounds to me like your card isn't in correctly, or is incompatible, and your internal memory is full. (it usually only stores a few photos for emergencies) Have a look at the type of card you have. If it says SDHC, or is 4GB or larger, it is not compatible with your camera and you need to get a 2GB. If not, it may not be inserted correctly. Push it all the way into the slot and it will click when it's in properly. Then try formatting it. Press review (where you look at the photos) and scroll down to setup- then look for 'format' and press okay. This should sort everything out. You can also copy the photos you've taken in the meantime from the memory to the card by pressing copy in the review menu and scrolling to the right. Hope that helps
Jul 26, 2010 | Casio Exilim Card EX-S100 Digital Camera
Jumpdrive states full but is not
File system error - format it the slow way in a different system.
Jun 15, 2010 | Lexar JumpDrive Classic Portable USB Data...
Flash drive says its full but it is new, never used
If it is brand new, you have nothing to loose: reformat the whole card using FAT32 if possible.
Jan 02, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
Memory Stick Pro Duo says it's full when not - photos to iMac
move the auto install file then reformat the flash drive as fat.
Apr 06, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Upgrade the Toshiba Libretto 50 CT
if you want to improve the speed of your laptop you could buy a faster harddrive with an higher rpm per minute than the one installed in the unit, that WILL speed up the system:), and yes its possible to boot from the 2gb flash card but i recommend if you are going to use a flash card you get a bigger one:)
Cheers
Jan 04, 2009 | Toshiba Libretto 50CT Notebook
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
Nikon D300 Body Only Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
