Question about Toshiba 26AV500U 26 in. LCD HDTV
No cable box, used to run through vcr, how do we get cable channels?
    Scholar:
  • 122 Answers
You should just connect the cable to the tv and then using the menu tell it you are on cable and have it scan for channels. Good Luck
Posted on Jul 22, 2009
  • laureliete Oct 20, 2010
    You can connect the cable to the in port on your vcr/dvd player (but only the one with the vcr in addition to the dvd will have the additional in port) connect another small cable with two pin ends from vcr/dvd out port to the only cable port on the back of the tv.
    If you do not have a player with an in and out port then use the tv if you can. I have comcast cable and you have to have two channel tuners to make that work. One tuner is my vcr/dvd the other is my tv. When you have the little cable box that is your tuner and your tv is the other. Without the vcr/dvd I was not able to get channels other than "3" 95 and 99. I have Comcast I would rather run it through the vcr/dvd then talk to them. (Usually avery unpleasant experience for me.)
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Iwas wondering if i could use it as a tv if i hook my cable box to it?
You can, if your cable box has RGB component or s-video or composite outputs and if you can change channels through the cable box.
RGB will give the best picture.
You could also run a vcr into the monitor and use the vcr to change the channels if the cable box will not do the channel changes for you or if the cable box does not have the right outputs.
You will also need a audio output jack on the cable box or vcr to run out to a receiver or stereo or to the monitor speaker bar
Oct 18, 2010 | Gateway FPD2275W LCD Monitor
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Loss of VCR Channels due to Digital Switchover
Comcast is full of it.
If you have a cable box, plug the box directly into the cable feed, then place the VCR inline between the cable and the TV. Leave the VCR on Channel 3 or 4 and use the box to select the channel. You could also use the video and audio out lines from the box and run them to the VCR.
Jun 18, 2009 | Zenith VCS442 VHS VCR
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
VCR tuner cannot tune in my cable channels
It is working as designed. The purpose of your cable box is to take in a wire containing all of the possible channels you might watch, and then extract *one* channel, and force it to appear as channel 3. If you connect the cable directly to the VCR, then the VCR's "tuner" (ie, channel selector) has an opportunity to extract any channel it wants. But... as you point out, your VCR won't be able to "see" any of the digital channels. So... if your goal is to be able to watch any of the digital channels, the signal must pass through your cable box, which will put the selected channel on channel 3. There is no value in going from the VCR to the cable box, since the VCR's tuner will have already filtered out all but one channel. It would be helpful to make a list of what your useage goals really are, since there are so many different ways to hook these things up. Are you interested in: - watching digital channels? - recording digital channels? - watching one channel while recording another? - using higher quality video signals (composite, s-video, component, etc) rather than RF (ie, channel 3) And so on. Keep in mind that you have *three* tuners: Your cable box, your VCR, and your TV. It sounds like only your cable box can tune in the digital channels. If your cable box puts out any non-RF signal, then the best choice would be to go: Coaxial Wire -> Cable Box -> Video Connection -> VCR -> Video Connection -> TV, with the VCR and the TV both set to "video". Then you would only use the cable box as a tuner, the VCR would only see the tuned channel (via video in), and the TV would see the same channel (or whatever tape you are playing) on its video input.
Mar 29, 2007 | Zenith VCS442 VHS VCR
Toshiba 26AV500U 26 in. LCD HDTV Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
