Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error Hi good morning, I am getting an error on the printer, RELEASE THE SCANNER LOCKSWITH AND THE POWER OFF AND BACK ON
  • 24 Answers
Scroll down the page and download th manual here this should help you with futher errors you incur on your MP830
Come back to me at fixya and we will help resolve your issues.
Posted on Nov 20, 2007
  • Sharif Dyson
    Sharif Dyson Nov 20, 2007
    If that link doesn't work get back to me, I have the .pdf manual on my desktop I can email to you.
Where is the "scanner lock switch" located on a Canon Pixma MP980 printer? I cannot seem to locate the switch "under the hood" so I need assistance.
The scanner lock on the MP980 is on left hand side of the scanner unit. It's closer to the hinge of the document cover and almost centered between the scanner glass and the edge of the printer. If you lifted the entire scanner unit, you won't see the switch. You should be able to push the switch towards the open lock symbol with your finger or thumb. The Getting Started guide has a pretty good picture of where the switch is in Step One. The guide is available on the product page, , in the Brochures & Manuals section. The current link to the Getting Started Guide is . After moving the switch, turn off the all-in-one. Then unplug the power cord to clear the error message from the printer's memory. After a few minutes, plug the power cord back in and turn on the printer.
If the error persists and the scanner is unlocked, the scanner mechanism may be damaged. If that's the case, your MP980 needs service. If the unit is under warranty, contact Canon. (If it isn't under warranty, you'll need to decide if the unit is worth the shipping and handling fees and the minimum $50 or so charge just to determine the problem at a service center. (That fee will be applied to the cost of fixing the printer, if you decide to have the technician continue to work on the unit.)
I hope this helps.
Sep 21, 2015 | Canon PIXMA MP980 All-In-One InkJet...
Scanner error message
is your printer is detected in the device manager settings??
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Cannon Pixma mp145 model error for scan i dont have need for printer i am using only scanner --------------------------- Printer maintenance is in progress. Scan after it is complete. Code : 2,114,0
According to you your scanner not working well which error code 2,114,0.
To solve this you can try the following
unplug cable
press and hold "power" button
plug cable
press "resume" and release
release the "power" button
At this stage, your computer will detect a new hardware.
Insert the the driver CD and update the scanner driver.
It may happens also for empty cartridge of also.
Replacing of your empty or dry ink cartridge can solve your problem.
Feb 04, 2011 | Canon Office Equipment & Supplies
I am using the hp psc 1613, this morning when i switched the printer on it gave me this error 0x07d54dd6
sounds like a memory error. Try unpluging the printer power and the data cable and plug the power back to see if it makes any changes
Aug 23, 2010 | HP PSC 1610 All-in-One Printer, Scanner,...
Epson workforce 600 displays message " A scanner error has occured. Please refer to documentation" How do I fix this?
Error 600
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 26, 2010 | Epson WorkForce 600 All-In-One InkJet...
Fax problem
first try to make a copy and check if you get the same error message..
if you get the same error message..try these steps..
1)connect the printer directly to the wall outlet..and try to make a copy..if you get the same error message..then go the next step
2)unplug the power chord from the back of the and hold OK and CANCEL buttons together..
3)while pressing these two buttons plug in the power chord to the back of the printer..after you plug in the power chord do not release the buttons untill the screen goes blank..
4)once the screen is blank release the buttons and turn ON the printer..
5)wait for the printer to complete the initialization..
6)then try to make a copy and check if it is copying successfully..
if not machine should be replaced because scanner bulb is not getting enough power or scanner bulb is gone bad..
please try these steps and let me if the solution has worked
Mar 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 6310 scans once but then says scanner failure
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
Scanner Error Power Turn off than on
If you are get that error message than unplug the power cord, and than press Poun and Number 6 Keys together on the keypab of the printer. While these keys are pressed and hold, than at the same time plugged in the power cord and dont release the two buttons.
After say 30 second you will get a new message on the screen of the printer.
All of the above steps actually reset the printer. I hope this will work.
Aug 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Mar 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the you have the install cd? if not try canon's site to download it.
Aug 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
