Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Crafstmen garage opener keypad problem
I'm able to close my garage door from my key pad but not able to open. I have replaced bateries made sure beam is aligned, any sugestions?
    President:
  • 3,197 Answers
I assume your hand remotes are working properly and if so your keypad is just sending out a weak signal. Best replace it.
Posted on Jul 22, 2009
Can not reprogram key pad on my liftmaster garage door opener ,tried every thing in the book ,hand held works and also i am able to open and close from the multi function door control.
If you are sure the battery is good and this doesn't work then you need to replace the keypad.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Dec 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Everything on the opener works fine but the key pad will not open the door when it is closed but will close the door when oprn
Make sure the battery in the keypad is good. A weak battery will cause this problem. If it is good then your keypad is going bad.
Nov 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
The key pad will close the garage door but it will not open the garage door.
If the keypad is the only remote unit you have that has short range then it is failing. The lack of signal strength prevents the signal from reaching the receiver when the door is closed. A replacement is the only cure.
Nov 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close with remote and I have to hold the pad to make it go down, however it opens just fine.
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving "eyes". These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye "sees" the beam from the sending eye, a green indicator light will glow on the top of the eye. Tweak them a bit. If both lights do not come on you have bad sensors.
Sep 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftmen key pad will not open garage but will close it
If the battery is good your keypad may just have a weak signal and needs to be replaced.
Aug 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
The garage key pad has stopped working
The most common problem for your situation is that the battery in your wallmounted key pad needs to be replaced. unscrew the little screw on the face of the device, remove the battery and replace it with one just like it. Radio shack usually has these batteries
Oct 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door is also on a key pad. It will not
COULD BE A WEAK BATTERY IN THE KEYPAD THE DOOR ACTUALLY RESTRICTS ABOUT 5-10% OF THE SIGNAL STRENGHT
Apr 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Key pad won't open garage door
You probably have an eletrical device that is messing with frequency. Make sure that everything is off inside garage.
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
74 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
