Question about Canon PIXMA MP160 All-In-One InkJet Printer
When i click to print, message pops out paper jam and printer flases e and 3
    Problem Solver:
  • 29 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tonl-i-6
Posted on Sep 04, 2009
    President:
  • 3,278 Answers
Check all areas to be certain that all stuck paper is removed. If all clear and the error still displays, reset the printer by the following:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Hope this helps.
Posted on Jul 21, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
Printer jam
hi,
toi-i-10
Jul 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
The paper is stuck while printing and the message is clear the paper jam
when it stuck, just click start menu below, under settings and printers and faxes. Then find the printer and double click and cancel all documents clear. So after doing it restart again your pc and try print another document.
May 09, 2009 | Office Equipment & Supplies
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Oct 27, 2008 | HP Deskjet 3915 InkJet Printer
Paper jam error message
Try this website for a paper jam problem with your printer.
Click Here
May 26, 2008 | Lexmark P4350 All-In-One InkJet Printer
Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Oct 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
87 people viewed this question
old marine
old marine
