Need a power fuse 5x20mm 75A/250V
I need to find a power fuse 5x20mm 75A/250V
  • 83 Answers
Radio shack they will have it or will order it !! Also check on line @ Wallco Industrial Electronics search for this item !! They have it also !1 swampratt200!!AAAEEE!!!
Posted on Jul 21, 2009
I need a fuse for my DAC15006R
slow -blow fuses used in electronic equipment are available from retailers like Jaycar or other electronic parts shops
Mar 21, 2016 | 3.15A 250V 5x20mm Slow-Blow Glass Fuse...
Do i have a blown fuse if I am checking 2 small fuses that are on a circuit board. one is 1.6 amp 250v and the other is 160ma 250v and the 160ma fuse is the one testing 1.4 and the 1.6 amp fuse is tes
They have a restorside, a bit , that's why you have fast and slow fuses. But if they were dead, then the resistant would be infinite, so
no problems with both fuses.
gr. Richard
Sep 12, 2014 | Roland Cube Street - Battery Powered...
My harman kardon avr 520 shorted out. i see 2 fuses blown 1 slow burn 7a 250v slow burn & 1 slow burn 2a 250v 5x20mm. Is this a good place to start fixing it? i had metat to metal shorting because of...
The output transistors are most likely shorted and need to be replaced. Since this was a short caused by user action, there is a high probability that other components further back into the circuitry is also damaged. This is not a repair that should be attempted by a homeowner. Incorrect repairs can cause further damage, so I would suggest that you at least get a repair estimate from a local shop. If you have any electronics experience, we can then perhaps guide you through the actual repair.
Please keep us posted.
Dan
Oct 12, 2012 | Harman Kardon AVR 520 Receiver
I have a Cannon 2020i Image Runner, we had thunder storms over the weekend with power interruptions. Came in today and copier will not power on. I have confirmed the receptacle is live, is there a...
You need to remove the back cover and on power supply pcb there must be fuse. I belive glass fuse 5X20mm, not sure for how much A.
For service manual and board circuit send me mail on emma.servis@gmail.com
Sep 07, 2010 | Canon ImageRunner 2020i Copier
It just stopped during use and seems completely dead!
Replace the fuse located below the plug inlet on the mixer,(it is a 6.3A Fuse, 250V 5x20MM fuse from Radioshack) you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Aug 11, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
No High Voltage
I finally got my hands on a manual. I haven't checked as yet, but there is a 4A 250V - 5X20mm Time Lag fuse (slow blow) under a plate next to AC plug on the rear panel. I pulled the back panel to do a visual and didn't see anything burnt or fried. I'll get back to you if I discover the fuse was blown.
Jul 06, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Need a T5H250V Ceramic fuse
693-0001.2511 order this part from mouser or allied, who ever you know that has time delay fuses 5x20mm 5 Amp 250V
Jun 09, 2009 | Philips Televison & Video
Where's the fuse?
Yup, I had the same problem. The unit just stopped working. I gather that this is a common problem with this model. I followed other posts elsewhere, and found the fuse behind and near the top of the control panel. There's a white, cylindrical plastic thing about 1.5-in long in one of the wires that run down from the main fuse in the upper right corner. Pop open the case (you may have to cut a plastic tie around it). I replaced the fuse. My microwave is working now. We'll see how long it lasts.
It's hard to tell what kind of fuse it is, but reading elsewhere, it's a 250V 4A 5x20mm slow-blow fuse.  I haven't found a ceramic one just like came out, but a 4-pack of glass fuses that fit the specs are $3 at Radio Shack. PN 270-1066. (No endorsement implied, it's just where I found something that worked.)
No, the fuse in question (and there appears to be another like it lower behind the control panel) isn't on any of the diagrams or parts lists.
Jan 10, 2009 | Whirlpool MH3184XP Microwave Oven
Fuse casing on subwoffer
I would recommend you to let the hardware vendor from whom you bought the speaker know this as they will replace the complete set.just give them a call and let them know
May 28, 2008 | Harman Kardon HK695 Computer Speakers
In line fuse
I suspect that the fuse is 0.75 A, and I believe that it is soldered in place. Can you see that it is blown?
Mar 27, 2008 | Bose Wave Radio
156 people viewed this question
 Grubhead
Grubhead
