Question about KitchenAid KEBC107 Electric Single Oven
Kitchenaid Superba electric convection oven not preheating right
I adore my Kitchenaid Superba convection range which is approx 5 years old. Recently, however, I notice that it seems to take longer for the oven to preheat (I always use the convection cycle). How long SHOULD it take to preheat to 325F? Any suggestions as to what the problem might be?
  • ptarmstrong Jul 24, 2009
    If the sensor was failing, wouldn't it be a problem using the oven at all? It does work perfectly in regular bake mode and preheats fast. By the way, there are 3 elements in this stove, broiler, lower covered plus 1 behind the fan on the back. Problem seems to be only for convection bake.
  • ptarmstrong Jul 25, 2009
    The fan is working absolutely perfectly and that is why I didn't really twig at first. Then, when it started to take forever to heat up in convection mode, I knew something was up. I cannot see the lowere element since it is covered, but since it does preheat just fine in regular bake, I am thinking it is more than likely the convection element itself. What do you think? Is there anything else it could be? Your help is GREATLY appreciated. THANKS!
  • KitchenAid Master
  • 3,361 Answers
Your temperature sensor is failing. Replace the temp sensor.
Posted on Jul 21, 2009
  • steve
    steve Jul 25, 2009
    Sorry, I mis-interpreted your post.
    Is the fan working in convection? Is the rear element working in convection?
  • steve
    steve Jul 26, 2009
    I am agreeing with you. The convection element may be bad. Unplug the range. Remove the cover for the fan and convection element. Remove the convection element. Use a volt/ohm meter set for ohms or continuity. Test the element. If it does not read any value,replace it.
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
Kitchenaid superba oven
What is the model number?
Jun 19, 2013 | Ovens
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
KitchenAid KEBC107 Electric Single Oven Logo
4,013 people viewed this question
Top KitchenAid Ovens Experts
ashburton
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
