Question about Compaq CPQ/Evo Maxtor 3.5 IDE 40GB Hard Drive (303593001)
Comes on tries to boot up then monitor goes black, and computer flashes red indicator light on front. I even switched monitors, it does the same thing. I work for a very small non profit getting homeless men off the street, and I need my computer to be operational. Thanks
Mostly this problem occurs due to dust, remove the RAM from cpmputer slot rub its notches with plain paper and reinsert it in same or another slot.
Posted on Jul 22, 2009
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Monitor Problem
Then your system configuration and the Operating System are not supporting each other.
OR
If you can arrange one more monitor, try connecting it and see whether even then it goes blank. If not then the previous monitor has some problem.
Regards
Dec 29, 2009 | Computers & Internet
Pl2010m orange standby light, black screen
Try booting the pc in safe mode (press f8 at startup). It may be possible that the pc is trying to send too high a resolution to the monitor...unlikely though. The symptom you describe usually indicates that the power board or the inverter board in the monitor are defective. If it does the same thing in safe mode, you have 2 options.
1. Replace the power board and inverter board (do the inverter board first.......it's the cheaper one (10-20 dollars).
2. Send the monitor back to the seller for a refund, or get a new monitor.
Sorry I couldn't give you more positive feedback. Hope this helps.
Joe
Oct 13, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
X2gen 22 inch monitor black all the time, flashing yellow power b
I had this happen to me, it finally wouldn't come on and I found 2 ballooned capacitors on the power board, they were 220uf 25v electrolytics, I replaced them and the problem went away immediately.
Jan 08, 2009 | X2Gen MG19MY 19" LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
Monitor problems
ok ,you may have two monitor drivers installed, or if it is wireless the driver may be faulty etc... a problem like this occur when you have two places on a monitor can be attached to your motherboard, direct or PCI, hat means look at the back of your comp. if there is a similar port that the one your using then when the monitor goes blank and just sits their, switch it over, and you should get an image. if its a driver problem, then safe mode will only work, and reinstall your PCI TO PCI or: your PCI BRIDGE drivers in the computer managment console. good luck. if all fails try using an older monitor or just a spare. cheers.
Sep 25, 2007 | Gateway FPD1760 17" LCD Monitor
Compaq CPQ/Evo Maxtor 3.5 IDE 40GB Hard Drive (303593001) Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
