Computers & Internet Logo
J
John Tustian Posted on Jan 14, 2017
'User Account Control, do you want to allow this app to make changes to your device? Service Control Configuration Tool. Verified publisher Microsoft Window, 'yes or no' I can't proceed to download
Panagiotis Zachos
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 24, 2017
Panagiotis Zachos
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1769
Points
You need to click yes to let the application run.
Need to know my user name and password to my text plus app
You can log into your Text+ account using your verified phone number or email address. Your verified phone number or email address is so important! They use this piece of verified information to confirm account identity, send new passwords, and look up your account. They can not make any changes to your account if you do not use your real information. Check for a password change link to get a new password.
Check the link for troubleshooting of Text+.
General Troubleshooting Steps
tip
Understanding windows account lockups
Common Causes for Account Lockouts
This section describes some of the common causes for account lockouts The common troubleshooting steps and resolutions for account lockouts are also described in this section.
To avoid false lockouts, check each computer on which a lockout occurred for the following behaviors:
* Programs: Many programs cache credentials or keep active threads that retain the credentials after a user changes their password.
* Service accounts: Service account passwords are cached by the service control manager on member computers that use the account as well as domain controllers. If you reset the password for a service account and you do not reset the password in the service control manager, account lockouts for the service account occur. This is because the computers that use this account typically retry logon authentication by using the previous password. To determine whether this is occurring, look for a pattern in the Netlogon log files and in the event log files on member computers. You can then configure the service control manager to use the new password and avoid future account lockouts.
* Bad Password Threshold is set too low: This is one of the most common misconfiguration issues. Many companies set the Bad Password Threshold registry value to a value lower than the default value of 10. If you set this value too low, false lockouts occur when programs automatically retry passwords that are not valid. Microsoft recommends that you leave this value at its default value of 10. For more information, see "Choosing Account Lockout Settings for Your Deployment" in this document.
* User logging on to multiple computers: A user may log onto multiple computers at one time. Programs that are running on those computers may access network resources with the user credentials of that user who is currently logged on. If the user changes their password on one of the computers, programs that are running on the other computers may continue to use the original password. Because those programs authenticate when they request access to network resources, the old password continues to be used and the users account becomes locked out. To ensure that this behavior does not occur, users should log off of all computers, change the password from a single location, and then log off and back on.
noteNote
Computers running Windows XP or a member of the Windows Server 2003 family automatically detect when the users password has changed and prompt the user to lock and unlock the computer to obtain the current password. No logon and logoff is required for users using these computers.
* Stored user names and passwords retain redundant credentials: If any of the saved credentials are the same as the logon credential, you should delete those credentials. The credentials are redundant because Windows tries the logon credentials when explicit credentials are not found. To delete logon credentials, use the Stored User Names and Passwords tool. For more information about Stored User Names and Passwords, see online help in Windows XP and the Windows Server 2003 family.
noteNote
Computers that are running Windows 95, Windows 98, or Windows Millennium Edition do not have a Stored User Names and Passwords file. Instead, you should delete the user's .pwl file. This file is named Username.pwl, where Username is the user's logon name. The file is stored in the Systemroot folder.
* Scheduled tasks: Scheduled processes may be configured to using credentials that have expired.
* Persistent drive mappings: Persistent drives may have been established with credentials that subsequently expired. If the user types explicit credentials when they try to connect to a share, the credential is not persistent unless it is explicitly saved by Stored User Names and Passwords. Every time that the user logs off the network, logs on to the network, or restarts the computer, the authentication attempt fails when Windows attempts to restore the connection because there are no stored credentials. To avoid this behavior, configure net use so that is does not make persistent connections. To do this, at a command prompt, type net use /persistent:no. Alternately, to ensure current credentials are used for persistent drives, disconnect and reconnect the persistent drive.
* Active Directory replication: User properties must replicate between domain controllers to ensure that account lockout information is processed properly. You should verify that proper Active Directory replication is occurring.
* Disconnected Terminal Server sessions: Disconnected Terminal Server sessions may be running a process that accesses network resources with outdated authentication information. A disconnected session can have the same effect as a user with multiple interactive logons and cause account lockout by using the outdated credentials. The only difference between a disconnected session and a user who is logged onto multiple computers is that the source of the lockout comes from a single computer that is running Terminal Services.
* Service accounts: By default, most computer services are configured to start in the security context of the Local System account. However, you can manually configure a service to use a specific user account and password. If you configure a service to start with a specific user account and that accounts password is changed, the service logon property must be updated with the new password or that service may lock out the account.
noteNote
You can use the System Information tool to create a list of services and the accounts that were used to start them. To start the System Information tool, click Start, click Run, type winmsd, and then click OK.
Other Potential Issues
Some additional considerations regarding account lockout are described in the following sections.
Account Lockout for Remote Connections
The account lockout feature that is discussed in this paper is independent of the account lockout feature for remote connections, such as in the Routing and Remote Access service and Microsoft Internet Information Services (IIS). These services and programs may provide their own unrelated account lockout features.
By default, IIS uses a token-caching mechanism that locally caches user account authentication information. If lockouts are limited to users who try to gain access to Exchange mailboxes through Outlook Web Access and IIS, you can resolve the lockout by resetting the IIS token cache. For more information, see "Mailbox Access via OWA Depends on IIS Token Cache" in the Microsoft Knowledge Base.
MSN Messenger and Microsoft Outlook
If a user changes their domain password through Microsoft Outlook and the computer is running MSN Messenger, the client may become locked out.
In this case, since the user has multiple devices connected to the exchange at given time , if he changes the password without disconnecting the other deivices. The account would get locked. You can inform him disconnect all the devices from the exchange except for one machine to change the paswword and then reconnect other devices with new creditentials.
Thanks
Proton
on May 29, 2010 • Computers & Internet
1helpful
Verify security
Fix Mail Apps and Devices Show Incorrect Password Error After Enabling 2...
[Fix] Mail Apps and Devices Show Incorrect Password Error After Enabling 2-Step Verification in Microsoft or Gmail Account "2-step verification" is an important security feature which protects your online account whether its your email account or a social networking account. It asks for an extra security code each time you try to sign in to your account. This security code is sent to your registered mobile phone or alternative email ID.
Recently Microsoft enabled this 2-step verification feature for Microsoft accounts which are used for emails, Windows 8, XBox, etc. On the other hand Google is already providing two-step verification in its Gmail service since long time.
If you enabled 2-step verification feature in your Microsoft or Gmail account, you might be facing a weird issue. If you try to access your email account using an email client such as Windows Live Mail, Thunderbird, Microsoft Outlook, etc, it'll now allow you to sign in using your current password. It'll show you an incorrect password error message even if your password is absolutely correct. The same problem will also occur if you try to sign in using your Microsoft account in devices such as Xbox 360 or Android smartphones.
Now the question comes why does this problem occur? Why do these mail apps and devices not accept your correct password? The answer is very simple. These mail apps and devices were not designed to ask you for the extra security code which is required for 2-step verification. Since these apps and devices don't ask for security code, the 2-step verification procedure is not completed successfully, hence you can't sign in using your credentials in those apps and devices.
So what's the solution? The solution is very simple. Every company which provides 2-step verification feature, also allows you to create special passwords for these mail apps and devices. You can create separate passwords for each app and device and then you can use that special password to sign in to those apps or devices. Now those apps and devices will accept the new password and will allow you to access your account without any problem.
So if you have enabled 2-step verification feature in Microsoft or Gmail account and if you are facing login password problems in mail apps or devices, you just need to create above mentioned special passwords or codes to sign in without any problem.
Just follow these simple steps to create app passwords for your Microsoft or Gmail account:
A. Create App Password in Microsoft Account 1. Open your Microsoft account security settings page by clicking on following link:
Open Microsoft Account Security Settings Page
2. You'll see "App passwords" section at the bottom of the page which shows following information:
Some apps and devices don't support security codes. In these cases, you need to create an app password to sign in. 3. Click on "Create a new app password" link and it'll immediately provide you a new password generated randomly.
Now you can use this new password to sign in to a 3rd party mail app or device.
B. Create Application Specific Password in Gmail Account
1. Open your Google account settings page by clicking on following link:
Open Google Account Settings Pag
2. Now click on "Security" tab given in left-side pane. Scroll down on the page and you'll see "Connected applications and sites" section at the bottom of the page.
3. Click on "Manage access" button and it'll open a new page showing following information:Some applications that work outside a browser aren't yet compatible with 2-step verification and cannot ask for verification codes, for example: email programs including Outlook, Apple Mail, or Thunderbird, older Android smartphones. To use these applications, you need to generate an application-specific password. 4. Type any desired name in given text box and click on "Generate password" button.create_application_specific_password_google_account.pngThat's it. It'll immediately provide you a new password which can be used in any mail app or device to sign in.PS: If you want to remove or disallow any mail app or device to access your account, you can remove existing app password or revoke access from devices using the same account security settings pages as mentioned in above instructions.
how that helps good luck.
Jul 24, 2014 • hotmail.com
List of commands for vista
CMD command list
http://ss64.com/nt/
Run command list
to open run Press and hold start button on keyboard and while holding start button press R just once, small run window will popup and you can type the commands inside the run box and press enter on keyboard or click ok to execute the command.
Administrative Tools
Administrative Tools = control admintools
Authorization Manager = azman.msc
Component Services = dcomcnfg
Certificate Manager = certmgr.msc
Direct X Troubleshooter = dxdiag
Display Languages = lpksetup
ODBC Data Source Administrator = odbcad32
File Signature Verification Tool = sigverif
Group Policy Editor = gpedit.msc
Add Hardware Wizard = hdwwiz.cpl
iSCSI Initiator = iscsicpl
Iexpress Wizard = iexpress
Local Security Settings = secpol.msc
Microsoft Support Diagnostic Tool = msdt
Microsoft Management Console = mmc
Print management = printmanagement.msc
Printer User Interface = printui
Problems Steps Recorder = psr
People Near Me = p2phost
Registry Editor = regedit or regedt32
Resoure Monitor = resmon
System Configuration Utility = msconfig
Resultant Set of Policy = rsop.msc
SQL Server Client Configuration = cliconfg
Task Manager = taskmgr
Trusted Platform Module = tpm.msc
TPM Security Hardware = TpmInit
Windows Remote Assistance = msra
Windows Share Folder Creation Wizard = shrpubw
Windows Standalong Update Manager = wusa
Windows System Security Tool = syskey
Windows Script Host Settings = wscript
Windows Version = winver
Windows Firewall with Advanced Security = wf.msc
Windows Memory Diagnostic = MdSched
Windows Malicious Removal Tool = mrt
Computer Management
Computer Management = compmgmt.msc or CompMgmtLauncher
Task Scheduler = control schedtasks
Event Viewer = eventvwr.msc
Shared Folders/MMC = fsmgmt.msc
Local Users and Groups = lusrmgr.msc
Performance Monitor = perfmon.msc
Device Manager = devmgmt.msc
Disk Management = diskmgmt.msc
Services = services.msc
Windows Management Infrastructure = wmimgmt.msc
Conrtol Panel
Control Panel = control
Action Center= wscui.cpl
Autoplay = control.exe /name Microsoft.autoplay
Backup and Restore = sdclt
Create a System Repair disc = recdisc
BDE Administrator = bdeadmin.cpl
Color Management = colorcpl
Credential Manager = control.exe /name
Microsoft.CredentialManager
Credential Manager Stored User Names and Passwords = credwiz
Date and Time Properties = timedate.cpl
Default Programs = control.exe /name Microsoft.DefaultPrograms
Set Program Access and Computer Defaults = control appwiz.cpl,,3 or ComputerDefaults
Devices and Printers = control printers
Devices and Printers Add a Device = DevicePairingWizard
Display = dpiscaling
Screen Resolution = desk.cpl
Display Color Calibration = dccw
Cleartype Text Tuner = cttune
Folders Options = control folders
Fonts = control fonts
Getting Started = GettingStarted
HomeGroup = control.exe /name Microsoft.HomeGroup
Indexing Options = control.exe /name Microsoft.IndexingOptions
Internet Properties = inetcpl.cpl
Keyboard = control keyboard
Location and Other Sensors = control.exe /name
Microsoft.LocationandOtherSensors
Location Notifications = LocationNotifications
Mouse = control mouse or main.cpl
Network and Sharing Center = control.exe /name Microsoft.NetworkandSharingCenter
Network Connections = control netconnections or ncpa.cpl
Notification Area Icons = control.exe /name Microsoft.NotificationAreaIcons
Parental Controls = control.exe /name Microsoft.ParentalControls
Performance Information = control.exe /name
Microsoft.PerformanceInformationandTools
Personalization = control desktop
Windows Color and Appearance = control color
Phone and Modem Options = telephon.cpl
Power Configuration = powercfg.cpl
Programs and Features = appwiz.cpl or control appwiz.cpl
Optional Features Manager = optionalfeatures or control appwiz.cpl,,2
Recovery = control.exe /name Microsoft.Recovery
Regional and Language = intl.cpl
RemoteApp = control.exe /name
Microsoft.RemoteAppandDesktopConnections
Sound = mmsys.cpl
Volume Mixer = sndvol
System Properties = sysdm.cpl or Windows logo key + Pause/Break
SP ComputerName Tab = SystemPropertiesComputerName
SP Hardware Tab = SystemPropertiesHardware
SP Advanced Tab = SystemPropertiesAdvanced
SP Performance = SystemPropertiesPerformance
SP Data Execution Prevention = SystemPropertiesDataExecutionPrevention
SP Protection Tab = SystemPropertiesProtection
SP Remote Tab = SystemPropertiesRemote
Windows Activation = slui
Windows Activation Phone Numbers = slui 4
Taskbar and Start Menu = control.exe /name
Microsoft.TaskbarandStartMenu
Troubleshooting = control.exe /name Microsoft.Troubleshooting
User Accounts = control.exe /name Microsoft.UserAccounts
User Account Control Settings = UserAccountControlSettings
User Accounts Windows 2000/domain version = netplwiz or control userpasswords2
Encryption File System = rekeywiz
Windows Anytime Upgrade = WindowsAnytimeUpgradeui
Windows Anytime Upgrade Results = WindowsAnytimeUpgradeResults
Windows CardSpace = control.exe /name Microsoft.cardspace
Windows Firewall = firewall.cpl
WindowsSideshow = control.exe /name Microsoft.WindowsSideshow
Windows Update App Manager = wuapp
Accessories
Calculator = calc
Command Prompt = cmd
Connect to a Network Projector = NetProj
Presentation Settings = PresentationSettings
Connect to a Projector = displayswitch or Windows logo key + P
Notepad = notepad
Microsoft Paint = mspaint.exe
Remote Desktop Connection = mstsc
Run = Windows logo key + R
Snipping Tool = snippingtool
Sound Recorder = soundrecorder
Sticky Note = StikyNot
Sync Center = mobsync
Windows Mobility Center (Only on Laptops) = mblctr or Windows logo key + X
Windows Explorer = explorer or Windows logo key + E
Wordpad = write
Ease of Access Center = utilman or Windows logo key + U
Magnifier = magnify
Narrator = Narrator
On Screen Keyboard = osk
Private Character Editor = eudcedit
Character Map = charmap
Ditilizer Calibration Tool = tabcal
Disk Cleanup Utility = cleanmgr
Defragment User Interface = dfrgui
Internet Explorer = iexplore
Rating System = ticrf
Internet Explorer (No Add-ons) = iexplore -extoff
Internet Explorer (No Home) = iexplore about:blank
Phone Dialer = dialer
Printer Migration = PrintBrmUi
System Information = msinfo32
System Restore = rstrui
Windows Easy Transfer = migwiz
Windows Media Player = wmplayer
Windows Media Player DVD Player = dvdplay
Windows Fax and Scan Cover Page Editor = fxscover
Windows Fax and Scan = wfs
Windows Image Acquisition = wiaacmgr
Windows PowerShell ISE = powershell_ise
Windows PowerShell = powershell
XPS Viewer = xpsrchvw
Open Documents folder = documents
Open Pictures folder = pictures
Open Music folder = music
Open Videos folder = videos
Open Downloads folder = downloads
Open Favorites folder = favorites
Open Recent folder = recent
Logs out of Windows = logoff
Locks User Account = Windows logo Key + L
1helpful
2answers
I'm am running a Dell Laptop E5530 with Windows 7 professional emulating XP. I installed 123CopyDVDGold software and upon completing the Installation the Windows "User Account Control Window" appeared and...
The quick answer is YES. But if you really don't want to see it pop up again call the support for the software vender and have them correct it so that it remembers you answers.
You also might see if their is a new update for the program or simply try another program altogether.
2answers
Your phone number its not allowed to use our service Galaxy grand samsung android 4.1.2 model number Gt-19082
i unistaled whatsapp n when i again install it therre is sum prblm in verifying my number :(
what is d solution
1helpful
I cannot access my transcend Elite software as my computer says publisher unknown. What do I do?
This is what I researched on the Microsoft support page. It seems that you have a issue with what is called the UAC (User Account Control>
Here is the explanation: this is from the KB article.
Explaining the User Account Control (UAC) technology
User Account Control (UAC) was a new security-feature and technology introduced first in Windows Vista™ and later migrated and added to Windows® 7.
The way UAC works: When we execute a normal program, UAC first checks if that program has keywords like "setup", "install", "update" etc, using the UAC Installer Detection Technology (IDT) (If is a setup.exe then elevate). UAC also checks the programs manifest file for the "requireAdministrator" tag added in its manifest configuration, if that is found, UAC will then go to the next step. When UAC has confirmed the first step, UAC will check if that program is
blocked by policy or if the programs publisher is blocked, when UAC successfully confirms that it goes to the next step.
When UAC has confirmed the first two steps, it then checks if the publisher of that program is "Windows®" it's self, but in our case it isn't so UAC goes to the next step and checks for a regular publisher. If the publisher is verified (this means also that the program has a valid digital signature) then UAC will prompt with a gray background and gold shield icon: "The application is Authenticode signed and trusted by the local computer".
UAC in Windows® 7: UAC under Windows® 7 is basically the same, except that they done some "small" modifications. But, still the same rules apply in Windows® 7 as in Windows Vista™.
The modern programs under UAC restrictions
Modern applications/programs that run under UAC restrictions have their power to become "trusted"-apps. Programs like Google Chrome or other (e.g. Avast Antivirus, Mozilla FireFox or any other), are put into trusted directories (e.g. C:\Program Files\ and C:\Program Files (x86)\), and they are of course signed with a digital signature [For example: A signature from the VeriSign Time Stamping CA].
Please contact the manufacturer
You will need updated driver set for your External USB storage device usually found at the manufacturers site. You can disable the UAC but this is not recommended.
I'm trrying to turn on the sound on this pc. But it won't let me get into the control panel without an administative passcode. What do I do?
I'm assuming this is your home pc. If you have setup an account on the pc as a "user", then this will not allow you to install apps or enable/disable devices on the PC.
Log in to the pc with the administrator account or the main account that was created and then try again
Hope that helps
How to configure samba server
Hi satveergaur
Follow these instruction to configure samba server
To configure Samba using a graphical interface, use the Samba Server Configuration Tool.
The Samba Server Configuration Tool is a graphical interface for managing Samba shares, users, and basic server settings. It modifies the configuration files in the /etc/samba/ directory. Any changes to these files not made using the application are preserved.
To use this application, you must be running the X Window System, have root privileges, and have the redhat-config-samba RPM package installed. To start the Samba Server Configuration Tool from the desktop, go to the Main Menu Button (on the Panel) => System Settings => Server Settings => Samba or type the command redhat-config-samba at a shell prompt (for example, in an XTerm or a GNOME terminal).
Note
The Samba Server Configuration Tool does not display shared printers or the default stanza that allows users to view their own home directories on the Samba server.
 Configuring Server Settings
The first step in configuring a Samba server is to configure the basic settings for the server and a few security options. After starting the application, select Preferences => Server Settings from the pulldown menu. The Basic tab is displayed as shown in Figure 24-2.
 Configuring Basic Server Settings
On the Basic tab, specify which workgroup the computer should be in as well as a brief description of the computer. They correspond to the workgroup and server string options in smb.conf.
 Configuring Security Server Settings
The Security tab contains the following options:
Authentication Mode — This corresponds to the security option. Select one of the following types of authentication.
ADS — The Samba server acts as a domain member in an Active Directory Domain (ADS) realm. For this option, Kerberos must be installed and configured on the server, and Samba must become a member of the ADS realm using the net utility, which is part of the samba-client package. Refer to the net man page for details. This option does not configure Samba to be an ADS Controller.
Domain — The Samba server relies on a Windows NT Primary or Backup Domain Controller to verify the user. The server passes the username and password to the Controller and waits for it to return. Specify the NetBIOS name of the Primary or Backup Domain Controller in the Authentication Server field.
The Encrypted Passwords option must be set to Yes if this is selected.
Server — The Samba server tries to verify the username and password combination by passing them to another Samba server. If it can not, the server tries to verify using the user authentication mode. Specify the NetBIOS name of the other Samba server in the Authentication Server field.
Share — Samba users do not have to enter a username and password combination on a per Samba server basis. They are not prompted for a username and password until they try to connect to a specific shared directory from a Samba server.
User — (Default) Samba users must provide a valid username and password on a per Samba server basis. Select this option if you want the Windows Username option to work. Refer to Section 24.2.1.2 Managing Samba Users for details.
Encrypt Passwords — This option must be enabled if the clients are connecting from a Windows 98, Windows NT 4.0 with Service Pack 3, or other more recent versions of Microsoft Windows. The passwords are transfered between the server and the client in an encrypted format instead of in as a plain-text word that can be intercepted. This corresponds to the encrypted passwords option. Refer to Section 24.2.3 Encrypted Passwords for more information about encrypted Samba passwords.
Guest Account — When users or guest users log into a Samba server, they must be mapped to a valid user on the server. Select one of the existing usernames on the system to be the guest Samba account. When guests logs in to the Samba server, they have the same privileges as this user. This corresponds to the guest account option.
After clicking OK, the changes are written to the configuration file and the daemon is restart; thus, the changes take effect immediately.
The Samba Server Configuration Tool requires that an existing user account be active on the system acting as the Samba server before a Samba user can be added. The Samba user is associated with the existing user account.
To add a Samba user, select Preferences => Samba Users from the pulldown menu, and click the Add User button. On the Create New Samba User window select a Unix Username from the list of existing users on the local system.
If the user has a different username on a Windows machine and will be logging into the Samba server from the Windows machine, specify that Windows username in the Windows Username field. The Authentication Mode on the Security tab of the Server Settings preferences must be set to User for this option to work.
Also configure a Samba Password for the Samba User and confirm the Samba Password by typing it again. Even if you select to use encrypted passwords for Samba, it is recommended that the Samba passwords for all users are different from their system passwords.
To edit an existing user, select the user from the list, and click Edit User. To delete an existing Samba user, select the user, and click the Delete User button. Deleting a Samba user does not delete the associated system user account.
The users are modified immediately after clicking the OK button.
Starting and Stopping the Server
On the server that is sharing directories via Samba, the smb service must be running.
View the status of the Samba daemon with the following command: /sbin/service smb status
Start the daemon with the following command: /sbin/service smb start
Stop the daemon with the following command: /sbin/service smb stop
To start the smb service at boot time, use the command: /sbin/chkconfig --level 345 smb on
Regards,
TheAssembler
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
