Question about Air Tools & Compressors
Inherited a Pro 4000 5HP 60 Gallon Air Compressor. 220 125 PSI maximum Pump #4029 Model Devilbiss RA5E60VAD When I power it on what other valve do I need to open if any? Can I print a manual on line? jnichols1@cogeco.ca
  • yadayada
    yadayada May 11, 2010
    we have no mauals here, try the manufacturers web site
  • 98 Answers
Heres a parts break down
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/devilbiss/RA5E60VAD_TYPE_1
for owners manual you can call Devilbiss and get one
Posted on Jul 22, 2009
Devilbiss 4hp 30 gallon air compressor wiring I
By safety valve you mean the tank overpressure release valve? Find the opening size in the tank first. Determine your compressors top psi it reaches when fully allowed to fill to max psi. Order valve that is rated ten psi more with that size fitting. Any brand will work, you just need that info and you can easily get one. It's hard to find exact parts for compressors but they are all basically the same setup
Oct 22, 2017 | Air Tools & Compressors
Devilbiss air compressor Running hot and low pressure
Chris:
Sounds to me like you have an air leak somewhere. When the compressor motor runs for too long a time, it's 'gonna get hot! Disconnect the fittings one at a time and use Teflon tape at each air connection. Check for leaks using a soap and water solution at each fitting.
Jun 02, 2013 | DeVilbiss Air Tools & Compressors
My 5 hp campbell hausfeld model hl 7017 pumps up to pressure but when it drops the motor starts but the compressor wont turn the belt just slips until pressure drops off to about 30 psi
Your tank check valve is not closing properly. It's a valve on the tank where the air line from the pump head attaches, It allows air in but not back out of the tank through the pump. When the pressure swtich turns the motor off, valve on the pressure switch lets the air out of the head so the motor can restart without any pressure in the pump head when the pressure in the tank drops. On rare occasion, you can clean the check valve out and it'll work again, more often than not you have to replace it.
Nov 24, 2012 | Campbell Hausfeld Maxus 60 Gallon (Belt...
Oil capacity for a devilbiss cac-4029 pump
The sears manual that has that pump in it lists the oil capacity as 16 oz. of 30 wt non-detergent oil. If you need parts, many are still available under other manufacturers like porter cable. Several parts are only available in kits. Ring kit KK-4313, Reed valves KK-4275, Gaskets KK-4312-2, valve kit KK-4315.
http://www.devilbissparts.com/OilLubeStat%20PDF%20files/cac-4029.pdf
http://www.mastertoolrepair.com/air-compressor-pump-parts-cac-4029-p-24953.html
Jan 09, 2012 | Computers & Internet
My compressor charges up to 60 PSI. It keeps on running but will not charge over 60PSI. I feel or see no leaks. Why?
Reed Valves in cylinder head. Pull head off and order Valve Kit through Campbell Hausfeld. Phone number etc is on internet.
Apr 27, 2010 | Campbell Hausfeld 26 - Gallon Air...
Compressor pressure only to 60 lb psi and no more
not sure but it sounds like the piston ring is worn out or you might have a bad valve.
p.s. its not your typical valve like in a car.
is it a wet compressor, check the oil.
Feb 21, 2010 | Coleman Powermate 27 Gallon Air Compressor
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Compressor won't kick back on when its suppose too
The tank check valve is probably bad. Folow the large discharge line off the head, disconnecting one end of it. If you get air out of the line you have a bad check valve. If you don't get air you are probably looking at a valve job.
Apr 04, 2009 | Dewalt d55151 factory reconditioned emglo...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
3,103 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
