Question about Simplicity Fashion Pro SW2145 Mechanical Sewing Machine
Simplicity Fashion Plus breaking needles
My machine suddenly started breaking needles. Any ideas on what might be causing this?
Thanks in advance,
George M.
  • 305 Answers
Needle guide may be slightly out of line, or bent, also chech base plate, maybe slack
Posted on Jul 22, 2009
My simplicity fashion pro sewing machine is not picking up bottom stitches. It won't sew at all, please help.
Install a brand new needle. If that doesn't help, most likely the machine has been knocked out of time--the needle and hook do not sync. Search for sewing machine timing or take it for service.
Dec 14, 2017 | Simplicity Sewing Machines
How do i thread the bobbin on simplicity fashion pro sw 2145
normally counter clock wise for bobbin, usually the first thread holder is used and the 2nd is used for double needles. here is a link for parts
Simplicity SW2145 Parts
Dec 06, 2014 | Simplicity Fashion Pro SW2145 Mechanical...
I have a Simplicity Fashion Pro SW2145. My bottom stiches are loose loops and it becomes a mess when I try to sew. I have changed needles, rethreaded, cleaned all lint, oiled, and it has not fixed the...
Most likely caused by issues with your top tension if it is showing on the underside of the fabric, top thread is not being tensioned fully or at all. Check the tension dial is set to five and that the top thread is between the tension discs and under tension.
Best way is to lower the pressure foot as this engages the top tension. Then pull the thread from below the tension device, down near the needle bar, it should feel firm to you.
If not, then check top threading again, rethread and pull thread into the tension device, and test again. If there is some tension there, then you could try turning the top tension dial up to a higher number a little to see if this helps with the stitching.
Failing that, take it for a service, tension device is probably faulty.
May 24, 2011 | Simplicity Fashion Pro SW2145 Mechanical...
The thread keeps breaking
try these suggestions
rethread machine
top tension to tight
needle is incorrectly inserted
thread & needle are not compatable---here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 06, 2010 | Simplicity Fashion Pro SW2145 Mechanical...
I have a Simplicity Fashion Plus
Possibly your thread tension is too loose--or your machine may need cleaning in the bobbin area.
Apr 11, 2009 | Simplicity Fashion Pro SW2145 Mechanical...
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Simplicity Fashion Pro SW2145 Mechanical Sewing Machine Logo
147 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
