Question about Echo Rapid Loader, Trimmer Head
How to remove trimmer head from Echo 230 SRM?
I am trying to remove the trimmer head that the Echo 230 SRM trimmer came with and replace it with a new U-Turn trimmer head. I read manuals and have not had any positive results. I even went to the place where I bought it from Home Depot and it's sad to say that they don't even know how to change it. Now if you ask me that's a disgrace. I took off the bottom spool section. After one takes off the nut and washer, what's left if the threaded screw and a spring loaded piece that is not coming out because it turns in both directions. If there is anyone out there that can be of assistance I would greatly appreciate it. Thanks in advance.
I know I'm replying to a old post, but this might help others. My Echo GT225 might be similiar. Once u are down to the thread bolt & the round shaft part that spins in ither direction, u need to thread back on the line spool, at lest the botton part of it to hold the thread bolt in place. Then start turn that rounded part that normally just spins, it will start to thread off, as you are thrreading it off you may have to also start threading the line spool part off as well at the same time. After that you will need the tool that takes off the C ring clamp thing that's underneath. I couldn't find any info on this online, I just kept on playing with it until I figured it out, UGH.
Posted on Aug 11, 2010
I wish I had an answer for you but I dont. Did you ever have any luck getting the stupid line head off? I just bought one myself and I can't the line head off either.
Posted on Oct 30, 2009
How do you remove the spool on an echo srm-2100 trimmer
Most units like yours has a tap head feed spool. To get to the line spool, you need to push the spool inward and rotate it to release it. The line spool is spring loaded, hence the need to push it in and rotate it to get it to release. You return the spool to the trimmer head housing after loading new line on it the same way, in reverse. Hope this info helps.
Sep 17, 2015 | Echo Garden
Echo SRM-230 trimmer stalls when you give it more gas. Can get more RPM with choke, but still not enough to use. Trimmer only has 20 hours on it.
empty the fuel tank and refill with the correct oil/ fuel mixture as too much oil blocks the jets Machines do not like any e- mix fuels as the jets are not set for the mix.
Jun 22, 2013 | Echo Garden
Dissassemble head assembly on Echo SRM-230
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Feb 03, 2012 | Garden
Echo weedeater srm 230 oi l for houseing what
See section 24 of your manual here. It has the information you want for lubing the flexible drive shaft and the gear-drive housing (if your unit is so equipped). This is a manual for the SRM230S model.
http://dl.owneriq.net/0/026b46f7-c706-4d99-8444-50bb35343992.pdf
Jul 23, 2011 | Echo Garden
Hello I have an SRM 240 Echo Weedwacker . I was dumb enough to try to take off the head and put a new head on - the new head I had was the wrong head so now I am lost on how to put the first head back on
Please see page 14 of the following manual for detailed instructions (including tools to use) in order to accomplish this procedure. You see, you have to lock up the gear drive so you can get the head back on the threaded end of the driveshaft.
http://www.echo-usa.com/pdf/documentation/SRM242410ES_042198.pdf
Jun 05, 2011 | Echo Rapid Loader, Trimmer Head
Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
How can I remove Echo 230 SRM trimmer head?
Don't know for sure, but I found manual on amazon, Amazon com echo srm manual so take a look if you want. have a nice day
Jul 21, 2009 | Echo Rapid Loader, Trimmer Head
Echo Rapid Loader, Trimmer Head Logo
2,945 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
