Question about Garden
The starter rope will not retract after a few pulls without disassembling the entire cover on the chainsaw and loosening the retractor wheel manually. How do I adjust the retractor(or the spring) to fix this problem?
    Sergeant:
  • 384 Answers
Rope guide is dirty...clean out and don't pull as hard.
Posted on Jul 22, 2009
Chainsaw starter rope won't pull
Pull your spark plug to ensure it isn't a compression issue or even piston/rod damage. If it still doesn't move, pull off your starter assembly and try to rotate the fly wheel by hand. If it turns, then your issue is in your recoil spring kit. You can replace the unit, or try to disassemble and reassemble.
Jul 30, 2014 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
Starter rope grabs at times. why?
try using the de-compression button when starting, will do the same as removing the spark plug but without removing the spark plug.
Failing that, remove the starter cover and check starter cord for daage or signs of snagging.
Feb 03, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Attempted to start unit, second pull, the pull rope seized up and would not release or retract. Approximately a foot of rope hanging loose.
    It has either broken the starter spring, or the pulley has jammed in the flywheel, remove the cover screws and take away the starter, if the c ord then retracts it was jammed, if not, slacken the centre fixing screw, does it retract now , if so the centre post is worn, and the fixing screws is clamping the pulley before it bottoms out on the top of the post, if it still does not retract, remove the centre screw and pulley, check the spring behind has not broken, be careful as it is a long spring under tention.
    Jul 19, 2011 | Poulan 14" Chainsaw
    The saw was working fine. I shut it off. When I attempted to pull the cord to start it again, the cord would not retract. I removed the cover, disassembled everything related to the cord. Made sure the...
    Many of these small saws have what is reffered to as an e start, the section that engages to the flywhell is seperate to the rope pulley, and is joined via a round coil spring, the idea is to soften out the compression and help to spin the engine over when cranking, one end of the spring fits into the outer flyheel engagment pinion, the other ends fits into a hole in the starter cord pulley, it does not fit into the main recoil spring, the securing screw for the assembly is a shoulder screw the idea is not to pinch the rewind mechanism when tightened, as this only screws into plastic it is very easy to over tighted and make the pulley post swell and stop the pulley rotating on the shaft, you may now need to leave the screw just a little slacker, the black plate under the starter is a conductor plate, this helps blow the cold air from the flywheel over the cylinder, this plate should always be there. When assembling the starter on the saw, keep pulling the rope as the cover goes on, this will ensure the pinion engages properly with the flywheel pawls.
    Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    Pull starter rope will not retract
    Disassembly and inspection/repair will be required. Here are the steps to take.
    Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers or a good flat blade screwdriver for some models.
    Nov 15, 2010 | Yard Machines Garden
    The starter rope on my B&S 375 engine snapped. Is it easy to replace? I took the cover off from around the starter and it seems to be popped riveted onto the top of the engine. Many thanks
    The pop rivets are irrelevant. if you look in the center of the nylon retract pulley inside, you'll see the screw that holds it all together. Take that screw out, and the pawl system will come out(make sure you remember how they came apart), then you can pull your retractor out, take the old rope out, put the retractor back in, wind it up all the way, then you can run the new rope in and tie the knot. Then let it draw the new rope in, put everything back together, and if you let it draw it in and had rope left over, pull it out about 4 inches before you put the handle on. Don't let go of the rope at this point, or you'l have to take it apart again. After this, make sure everything's back together the right way, and put the cover back on.
    Mar 11, 2010 | Garden
    Starter rope will not retract
    Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
    WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
    Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
    Start Pull cord replacement on John Deere s1400
    Take the 4 bolts/screws loose that hold the shaft onto the weed-eater body, You will see the clutch drum, you need a long T20 TORX driver to loosen the screw in the center of the drum shaft. The screw probably won't come all the way out, so just pull the drum off as you loosen it.
    Next you will see 3 flat clutch discs.
    You may need to remove the spark plug and stuff some starter rope in the combustion chamber to keep the shaft from turning.
    Unscrew these one at a time with a pair of large slip joint pliers. Be careful not to bend them and note which way they face. They unscrew clockwise I believe.
    Once you have these out of the way, continue taking apart the plastic housing to gain access to the starter rope assembly. There is a spring under the rope reel, so remove the screw holding the reel in place and carefully remove the rope reel and spring.
    Replace the rope, put the reel back in place and make sure the sping egages the little tab. Then wind it a few turns until there is moderate tension on the spring.
    Feed the rope through the body and tie it to the T-handle. Replace the hold down screw that keeps the rope reel in place.
    Test the pull tension before reassembly. It should retract the rope fully without too much tension and should not be loose. Lubricate the rope reel where it rubs against the housing with some light grade oil or lithium grease.
    If everything functions, put it back together in reverse order.
    Remove the rope from the combustion chamber and make sure there is no debris in it. Install the spark plug. You should be ready to go.
    Aug 21, 2009 | Garden
    Starter rope will not retract.
    inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
    Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    Garden Logo
    165 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
