Question about Evenflo Triumph 5 Comfort Touch
I have evenflo carseat model number 3591288 p1 and took off the cover to wash it and now the straps are not correct
SOURCE: Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
Posted on May 30, 2007
  • 5 Answers
SOURCE: Carsear Straps
I believe page 3 is what ur looking for. I have done this SOO many times, they get soo dirty soo quick!! Good luck and be safe!!
http://www.elitecarseats.com/assets/product_files/instructions/Eddie-Bauer/EddieBauer_3in1_manual.pdf
Posted on Nov 20, 2007
SOURCE: carseat harness straps
You have to unloop the straps from the gold metal bar. This will allow the straps to be free so you can feed them thru the holes and re-feed them into the proper height hold. You will than noticed that there are loops at the very end of the straps which you can loop back onto the gold metal bar.
Posted on Dec 01, 2007
quare3
  • 48 Answers
SOURCE: Reassembly of carseat
Here's something you can read... Please dont forget your rating...thanks.
http://www.coscojuvenile.com/instructions.asp
Posted on Jan 24, 2008
  • 3 Answers
SOURCE: eddie bauer convertable car seat
Product number and the manufacture date is located on the side, back, or under the base.
Posted on Oct 28, 2008
Is this carseat expired
Hi Angie,
Here is a link to Evenflo Support
Good Luck!
JP
Evenflo Product Support
Jul 14, 2015 | Evenflo Baby Gear
Evenflo carseat,can't figure out the straps after washing
You need to put the straps throught the bottom, then the top openings you put it through the 2nd **** or where the baby will be comfortable. Then you tie it on the back.
Jun 17, 2009 | Baby Gear
Need to get the carseat apart for cleaning
You can download the manual from evenflo web site with your model number. You will be able to remove the 2 small metal clips at the bottom of the seat by twisting it gently. Then you insert it through the slot.
Mar 19, 2009 | Evenflo Embrace
I have the Eddie Bauer carseat and the model # 22880-MTT EB ADJ Booster, MFG L #14 B 031328 10/26/07. i took the cover off and washed it and the suade got messed up... That was my fault. It srunk a...
Go to the manufacturer on line, find customer service or support and give them the model number... they may be able to direct you, or they may even have the parts.
Jul 02, 2017 | Car Audio & Video
I need this car seat manual bad!!!!
if you have a 22260 car seat is easy
1, on the base of the seat there is a push down clip that you need to push down and remove the steel bar of by sliding it out
2 unclip the seat strap for the seat by removing the brass "Y" on the back .PAY ATTENTION ON HOW YOU REMOVE THE STRAP IS ALL ONE PICE AND YOU NEED TO LOOP IT FROM ONE SIDE TO THE OTHERE
3. on the back of the seat there is 2 screws that you need to remove. the you remove the adj. back.
4. remove the cover and wash you can place it in the dryer or hand out to dry
5. instill the same way you removed
good luck
Aug 04, 2008 | Baby Gear
Evenflo car seat
1. Remove the cover on the back upright (8 phillips screws).
2. Remove the white plastic clips that retain the brass clip holding the shoulder straps in place.
3. Pull the brass clips away slightly, then, turn them and push through the slot where the shoulder straps go through to the front of the car seat.
4. Pull the straps through the lower seat cushion slots.
5. Wash and reverse steps above to put back together.
Jul 27, 2008 | Evenflo Generations
Stroller pad cleaning
You can remove the seat pad by unsnapping the two straps on either side of the bottom of the pad (where it covers over the metal frame). Then just thread the buckles through it. As far as the rest of the fabric such as canopy or fabrice sides, no luck. I got this stroller used and wanted to wash it all. I ended up just putting it (minus the removable pad) into my shower and washing it with the shower head. Then I got a Mr. Clean magic eraser and cleaned up the plastic parts. Now it looks so good!
Hope this helps...
Jan 03, 2008 | Evenflo Aura Traditions Travel System...
Carsear Straps
Nov 01, 2007 | Eddie Bauer Deluxe Convertible
Carseat harness straps
Sep 23, 2007 | Baby Gear
Garage Sale Car Seat
If you push down on the top of the handle you should then be able to move it. Also, to remove the straps you have to feed the bottom portion of the straps from underneath the seat up through first and then you should be able to feed through the material to remove the pad.
Aug 18, 2007 | Evenflo PortAbout 5 Infant
Evenflo Triumph 5 Comfort Touch Logo
1,002 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
