Question about LG Heating & Cooling
Lg art cool error code c6 - LG Heating & Cooling
SOURCE:
SOURCE: ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL NUMBER LSZ244VM4
Error C6 on lg cool art is common. you guy need a new CAPACITOR. cost $7.05c aud. it's 6uF 450vac.
take about less than 10min to install.
my lg model is lsz244vm-4, it's run well now.
Posted on Mar 04, 2008
  • 3422 Answers
The first thing i'll say is you will need to get it repaired by a technician and i strongly recommend you not to do it by urself.
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit.
Goodluck..
Posted on Mar 22, 2008
  • 95 Answers
SOURCE: Error C5 LG Art Cool Split System Air Conditioner
Probably a capacitor in the either the compressor or outdoor fan. Don't know if they are dual capacitor or each has it's own. This is just according to the other posts on this site. I would call in a tech to have a look at it. Should be able to diagnose this in about 10 minutes.
Posted on Jun 09, 2008
  • 234 Answers
SOURCE: LG error CH 64
What is the model of the unit?
Posted on Apr 07, 2009
hvac1960
  • 2133 Answers
SOURCE: Our LG Art cool Airconditioner
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Posted on Jan 20, 2011
I have a C6 error message on my LG LSZ244VT-5 AC Unit. How do I fix
LG Split System Air Conditioner Error code = C6 or CH06 LG AC Fault Definition = Excessive current at inverter DC power circuit - DC Peak Power
Flashing Light = 6
Display = Indoor Outdoor
Indoor Operation = SHUTDOWN
There are several things that can cause this,, first step is to check all wiring connections, but this can be pointing to a more major issue, the AC to DC transformer,,
It is a experienced tech kinda job
Jun 30, 2018 | LG Heating & Cooling
LG airconditioner gives error code C6 can you explain what this means
I'm seeing a c6 as a outlet pipe temp sensor fault. The temp sensor on the larger copper needs replaced.
Jun 20, 2018 | LG Heating & Cooling
C9 error code lg cool art
let the technicians do it for you,one of their sensor got faulty
Apr 21, 2014 | Heating & Cooling
LG Art Cool Error Code CA
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
May 04, 2010 | LG Art Cool LA181CNW Split System Air...
C6 error
Inverter compressor run current high. Check compressor windings all equal 1 to 4 Ohms, Check to earth 50 MOhm minimum, check run current
Feb 21, 2010 | LG Art Cool LA121HNP Split System Air...
Error Code on LG Art Cool
error code CH22 is either compressor or inverter fault.
Jun 01, 2009 | LG Art Cool LA091HNP Split System Air...
Displaying "Co" code, and running when turned off with the remote
It sounds like you have lost communication between the indoor and outdoor units. This can be one of two things. Either the connection indoor or outdoor is loose or bad, or a rat may have eaten the cable in cieling.
Feb 28, 2009 | LG Art Cool LA121HNP Split System Air...
Lg Art Cool
Checkout the manufactures specs and model # on the webpage!
Sep 02, 2008 | LG Art Cool LA121CNP wall/window Air...
Jan 05, 2008 | Computers & Internet
Heating & Cooling Logo
750 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
