2000 Dodge Durango blower switch needs replaced as it only works on high. We need instructions on how to remove the front panel and install the new switch. Can you help? Chess
  • 5 more comments
  • lkukura Jul 21, 2009
    This is not correct. It is the switch not the motor. it is on the front panel where the knobs are located.
    Hi: Chess is going to try. I'll let you know. Thank you. I hope you are right. Linda
  • lkukura Jul 22, 2009
    WE are having trouble pulling the resistor off. What do you do with the red clip?
    the part they gave me at my garage is not remotely close to what you are showing us. So I will have to get the part tomorrow. I'll let you know. Thanks for your help. lk
    Hi: It works but not the correct way. The 1st position (left is now the highest setting and the position on the right is the lowest and the 2nd position on the right is off. What am I doing wrong? Linda
    Also I have a leak on the passenger side by the tire, it is also an a/c problem but my temp. guage is not cxlimbing. The radiator seems fine do you have a suggestion as to what this might be? It is leaking green. Thanks, lk
    The solution was helpful. Thank you. l
  • 3,037 Answers
Yep, perfect diagnoses, usually called a blower resistor though.I've had to replace a few in my time. Fairly simple to replace. Anyway just click on the following website link for complete instructions and pictures on how to replace this. Let me know how it works out.
http://www.gtrippleb.com/auto/durango/tech/durango_blower_resistor.htm
Benjamin
Posted on Jul 21, 2009
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Jul 21, 2009
    No when the blower only works on high, it indicates that the resistor between the controls(switch) and the blower motor is burnt out and needs to be replaced. Your controls are fine I believe, and the resistor is cheaper to replace by a long shot even if it would turn out not to be the problem which I am sure it is.
    Otherwise, if you still feel the need to replace the control switch, the plastic panel directly around the controls pulls off (pry it with a screwdriver, it is held on with clips) and gives access to the screws holding the controls on though I think you will be wasting your time to replace this.
  • Benjamin Patri
    That link I posted before was not trying to replace the blower motor, but was trying to replace the blower resistor which can be seen in the bottom picture on that website link. I hope you understand, if you are still confused, please let me know and I will try and clarify it for you.
  • Benjamin Patri
    no problem, good luck
  • Benjamin Patri
    Benjamin Patri Jul 22, 2009
    ok, in dodge cars it looks like a bunch of metal coils generally so maybe that is what the part they gave you looks like. I will see you tomorrow then.
  • Benjamin Patri
    The red clip should slide sideways to unlock it, then you should be able to get the resistor detached.
    Sorry that I missed this question before
2000 durango blower
The blower motor is located under the passenger side of the dash. there should be power on the dark green wire at the blower motor. If there is no power check the 40 amp blower fuse and the blower relay. If there is power than ground the light green with white wire with the blower motor plugged in. If the blower does not come on than the blower is bad. If the blower comes on than you have a ground issue. The system is ground side controlled which means the switch provides ground. If the blower does not work on high I would suspect the ground wire is burnt on the backside of the switch since high speed bypasses the resistor.
Apr 30, 2013 | 2000 Dodge Durango
Blower motor quit 2000 Dodge Durango
remove right front door sill trim panel.and remove the right side interior cowl trim cover.you should see blower motor.
Dec 10, 2009 | 2000 Dodge Durango
2003 Dodge Durango A/C Heater Blower does not work?
Sounds like a bad blower motor resistor. That part is what changes the speed of the blower, and your original blower motor may not be bad if it was running on high only. It may have been the resistor.
Aug 18, 2009 | 2002 Dodge Durango
Heater blower
your blower resistor is bad
Apr 21, 2009 | 2001 Dodge Durango
Replace durango blower motor resistor instructions blower only works on high
you may need to replace the switch,,,they wear out sometimes and only work on one speed.
Feb 16, 2009 | 2002 Dodge Durango
2003 Dodge durango, the blower motor stoppped came back on and stopped again and never came back on. I replaced the blower motor and still no air. Can anyone help?
Aug 01, 2008 | 2001 Dodge Durango
2002 Dodge Durango
blower motor resistor maybe why it only blows on high
Jun 25, 2008 | 2002 Dodge Durango
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
