Question about Carrier 38CKC030 Air Conditioner
Coil and fins start ice up
I have a Samsung Split unit. Unit (A) is on the lower floor, and works fine.
Unit (B) is on the 2nd floor which is giving me a problem. The unit is about 5 years old. The other day when it was hot I turned on the upstairs unit. I noticed the upstairs unit not blowing cold air like it used to. I cleaned all the filters and made sure everything was clean. I turned on the unit again and within about 3 min. I noticed ice build up on the fins and coil. What can cause this?
    President:
  • 2,976 Answers
The fins are dirty. They need to be washed every year or two with an acid based cleaner. They MUST be rinsed completely.
Posted on Jul 21, 2009
LS-1260HL split A/C. Why isn't it blowing at full speed in cool mode?
ice on indoor units can be from blocked evaporator fins / blocked filters
inspect the fins under the filter pads and if they look greasy and dirty have the indoor unit professionally cleaned as it is messy
Jan 23, 2016 | LG Heating & Cooling
Carrier split unit aircon mdl 42P100c has water dripping from the unit mounted internally onto floor.
Due to non maintenance of a/c. Col and air filter dust blocked. Due to this, some time ice formation over the coil will be there. Clean air filter, coil and blower wheel. And also drain pan.
If you see any ice formation over the coil after service, it's meant for short of gas. Thanks.
Jan 11, 2011 | Heating & Cooling
My SAMSUNG RF26VABWP WATER UNDER CRISPER DRAWERS CAN NOT FIND WERE IT IS COMING FROM. I HAVE WATER IN THERE EVERY DAY. I FOUND WATER ALL OVER THE FLOOR AND HAD CLEANED IT UP AND A WEEK LATER BACK AGAIN. I...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Apr 25, 2010 | Samsung RS2630SH Side by Side Refrigerator
My Amana AFB2534DEW fridge is leaking onto floor, no visible leak coming from inside fridge or freezer. Unit does not have ice maker or water dispenser. Please help diagnose problem... Thanks
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jan 07, 2010 | Amana AFB2534DE Bottom Freezer French Door...
I got a sam sung split A/C while switch on the
just check the gas pressure and gas pressure is ok,may be out door unite is blocked.do the high pressure service
Oct 17, 2009 | Samsung AS1293L Air Conditioner
Have Whirlpool ET8CHMXKQ05 that seems to be defrosting itself. Water is dripping from top piece in lower unit. Works fine except for that. How can I fix this? Thanks! Ice maker has never been connected.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 10, 2009 | Refrigerators
Refrigerator freezer drains keeps freezing over, not plugged.
Jul 02, 2009 | Refrigerators
Airconditioner has weak cooling power.
if all the coils on the out side and inside units are clean and the fan motors are running fine it sounds like it could be low on freon
Dec 11, 2008 | Heating & Cooling
Ice on the coil fins of my Window AC unit......
set your unit to fan mode only, to thaw the ice, after the ice melts, look at your evaporator coil, see if its dirty, if its dirty, then you might just need a good cleaning. if the coil is clean, look at your thermostat setting. it should not be all the way cold. the compressor would run continously and it would freeze the coil. third, the refrigerant system could be partially clogged up or it lacks refrigerant. these problems initiate freezing of the coil.
Feb 18, 2008 | Carrier 52PQ307 Wall/Window Air...
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Carrier 38CKC030 Air Conditioner Logo
152 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
