I have lacie rugged 2.5" hard drive 500 gb portable mini external hard drive and password protected. Then i forgot the password. so my question is how to recover password of this external hard drive
Did you get it fix ? Have the same drive and forget the password!! Need help
Isai (hyjacking External HDD posts "? why:?
marked RUGGED he said, you too.>
NO PC told
no external drive model told locked , STHR500800
NO photo posted of failed screens.
or is the boot drive locked
or bios locked
or windows bitlocker locked.
we can not guess locks blind, save a dEity.
learn to post photos of locks (errrors)
does drive fail on 2nd PC, amazing no, this test.
yes/ no?
do have this.
LaCie 301087U Safe 500GB USB 2.0 External Hard Drive with Biometric Access and Drive Lock
has finger print reader on top
we can not guess HDD ever. vast are made even by them.
USB or
Estat
or firewire,
no one posted told how connected or the model how sad that is.
now a lesson in encryted drives ,
the lock can be in
HDD or in SSD
in BIOS
and in windows.
in this case NOT bios, for external
the rugged drive above is also marked Secure
and offerss this.
Enable security (users manual clear is day)
Toolkit is required to enable security for LaCie Rugged SSD. Be sure to install Toolkit in order to password-protect your device using Seagate Secure 256-bit encryption.
as you can see it is SEAGATE inside.
STHR500800
this is my wild guess, no model ever told
here
https://www.lacie.com/manuals/rugged-ssd...
all you can do is guess
or the data is gone !
that is what you paid extra for , FOR SURE
next time tell model of drive.
and if fails on 2 PC.
ENGINEERED TO FAIL FOR JUST THIS REASON (NOT SOME ACCIDENT)
THE GOAL WAS DAY 1 ON THE DRAWING BOARD
100% FULLY SECURE ENCRYPTED DRIVE AND APP TO RUN IT.
100% fAIL BY DESIGN, THE RUSSIANS STEAL IT AND ARE FOILED. 2 WAYS, THE KEY IS LOST AND THE PW TOO,
SO MOVING THE HDD , IT FAILS FOR BOTH. HARD HARD FAIL.
YOU CAN GUESS IT OR OTHERS.
OR ERASE THE DRIVE.
WIKI COVERS THIS TECH, READ IT?
https://en.wikipedia.org/wiki/Hardware-b...
JUST ONE EXAMPLE OF MANY SYSTEMS.
AND EVEN MORE COMPLEX AND DEEP THE SOFTWARE WAY
https://en.wikipedia.org/wiki/Comparison...
one Lacie uses the seagate engine to do that.
no model told by you, at all,
SOURCE: cannot access my lacie rugged
Go to computer Management, change the drive letter from F:\ to any letter.
SOURCE: lacie 250 gb (neil poulton) external hard drive
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
SOURCE: Forgot Acomdata External Hard Drive Password
Did you every get this resolved? I have same probelm.
SOURCE: Lacie 1T Poulton design external hard drive is clicking
Before you resort to freezers and desperation, know that the external power supplies for these things are a. crucial and b. delicate. If the output voltage is down for any reason, it can produce the same clicking symptoms. I would get to a repair shop, and ask them to test the drive with a 'known good' power supply. I did so this very morning with a LaCie drive: no more clicking, happily mounting drive...and power supply replaced under warranty. Good luck
SOURCE: hard disk replacement for lacie ethernet disk mini 250 gb
I managed to fix mine with a little bit of work.
This website has a readme file that specifies the partitions. You must be using Linux.
http://gpl.nas-central.org/LACIE/ethernet_disk_mini_v2_-_ethernet_big_disk/EDmini_v2_partition_images/Readme
1. Plug the drive in a Linux computer, or use a Linux Live disk.
2. Create all the partitions according to the readme file. Use extended partition for the first "container". Linux Swap for the second partition. Use Ext3 format for the remaining.
3. Extract all the SDA6-8 files with bzip.
4. Use "dd" command to write those images to partitions sda6 - sda8 which you just created with this command: dd if=/dev/home/ubuntu/sda6 of=/dev/sda6 bs=512
5. Substitude /home/ubuntu above for the location where you placed the image files.
6. Once all 3 images have been written, the drive should be good to go. Put it back in the edmini, start it up and see if the website comes up. You may have the "format" the drive from the admin utility once its up and going.
Hope this helps.
use the "dd" command in
Hi Dastagir Mulani, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
no computer told at all
no error photos posted of the error.
external must be a self encrypted drive. SED
or do you use BITlocker on it. we can not guess use.
the lock is in the drive or in the app called bitlocker. or even other apps.
nobody on earth can guess how it got locked
by APP or in the drive
worse no drive model told at all, just 500 size.
useless facts all that.
now some facts, regardless of above'
1: SED drives can not be hacked, guessing sure.
they were sold or EXTRA cash just for that fact
its called full security. But most can be erased.
2: bitLocker (or others like it ) the same exact answer,
next time write it down or use lasspass.com
3: not told , is there data there not backed-up elsewhere?
wow, what key question that is... no?
and now the big test
move the USB?external drive to good PC #2
does it fail there???? yes,
then the drive is SED, locked.(self locked)
only erasure works now. for a fact.
