Question about Cell Phones
My iphone has white screen with *** line in the right side of the window
  • 3 more comments
  • yokosansan1 Jul 21, 2009
    no way i do this at least 1 times te last time i hold'm for 5 min. I try to restore y it's work ant the itunes accept the dievice and recognice but still in the same
    At this moment the windows turn black whith a white line in the right side.
    still with white window and the left side gray line
  • yokosansan1 Jul 22, 2009
    Yes the phone turns down and then on again when a reset using the home btton and the power on button, i will try these reset many time i will try few more times, anything else
    did you recomend ny sotre to refurnish the unts , we dont have any guaranteeat this moment
    Novelist:
  • 117 Answers
Have you tried a hard reset yet for this device? If not press the Top button of your iphone and the home button at the same time for 10 seconds and the iphone will reboot/restore the software not destroying your important information. It will go black then you should the apple logo come up and reset software for a short while. when its done you will see your home screen. Let me know if that helps
Good Luck!
Ruben
Posted on Jul 21, 2009
  • 3 more comments
  • ruben barrera
    ruben barrera Jul 21, 2009
    okay. have you tried to reset the device w/out plugging it into the computer? the hard reset is an attempt to reset software without pluggin in to the computer. try this again please first: do no plug into computer while you do this
    Press the home button (the big circle below the screen) and the
    sleep wake button (the button on top of the iPhone) simultaneously.
    Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
    The iPhone should now shutdown automatically
    Turn the iPhone back on by hitting the sleep/wake button.
    You should now see the Apple logo, your iPhone is restarting and bootin up.
    get back with me if you attempt this and it fails
    Good Luck!
    Ruben
  • ruben barrera
    the logic board is not responding correctly. i suggest you try this again. please update me. let me know if the screen shuts down like it is suppose to during the steps and if this issue comes up when your iphone comes out of the restore mode
  • ruben barrera
    i have seen issues where you had to perform this hard reset at least 5 times. it sounds ridiculous i know, but so is the underlying problem with these devices, you are not alone with the problem. so i know it sounds monotonous but continue the hard reset a few more times and update me
    Ruben
  • ruben barrera
    ruben barrera Jul 22, 2009
    to be perfectly honest this is the only known solution for the iphone white/black screens of death. and to speak frankly the issue will continue after this. if this unit is still under warranty i suggest taking it back and getting another unit. it will be more than likely refurbished. the issue is coming from the unit warming up and i believe it has affected the video chip that powers the screen causing the lines and the white screen. this happens very often on laptops and ps3's also. its the problem with people racing to get this new gear out and not testing the soldering and overheating issues correctly. if these hard resets do not work, try your hardest to get it replaced. my best to you!
    Good Luck!
    Ruben
  • ruben barrera
    would you clarify your last comment?
My iphone screen is white and has green lines on the right side. can anyone help with this?
Was Iphone dropped? Probaly needs to be taken apart and lcd needs to be reseated....
Let us know, estimated cost if sent out less than $50
Dec 02, 2009 | Apple iPhone 3G
White screen with black lines on right side
You Iphone LCD screen is damaged. Did you accidentally drop it recently?
No matter, you need to get the LCD screen replaced.
Check out the following link for your repair options.
Damage Iphone Screen Repair
Nov 09, 2009 | Apple iPhone Smartphone
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
My iphone's screen is white with vertical stripes
try to restore ur fone manually.
that should work
Dec 29, 2008 | Apple iPhone Smartphone
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Cell Phones Logo
64 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
