Question about Refrigerators
Kelvinator 380 frost free been turned off a while won't turn back on ?
No power
Fridge-kelvinator 380 impression series 380 frost free
sadly no question posted gets no answer . we are not mind readers
Jan 14, 2017 | Frost Refrigerators
How do I stop food freezing in the main part of my Kelvinator Twin air no frost 500 series refrigerator
there is a dial inside the refrigerator side to turn the temp up or down . rotate the dial to a lower number for warmer
Aug 31, 2016 | Kelvinator Refrigerators
Dell optiplex 380 won't turn on
steve it can be many things.3-4 but you don't give enough information
Apr 03, 2013 | Dell OptiPlex 380 MT Desktop Computer...
Polaris 380 wheels won't back up
open up unit check hoses on inside if they are off put on and zip tie
Jul 21, 2012 | Polaris 380 In Ground Pool Cleaner
Kelvinator c302f-r fridge is freezing everthing
sounds like thermostat if its non frost free model,otherwise it is temp sensor.need model number to clarify.
Apr 25, 2012 | Kelvinator Refrigerators
Kelvinator fridge freezer, fridge too cold frosting at back
Fridges that are less then 10 years old have a lot of POWER. To get rid of the frost, wait until you have eaten most of the food up (maybe a few days), then unplug the fridge and leave the doors open. This will take care of the frost after several hours.
From then on, make sure that when your fridge is full, use a higher setting, and when it is near empty or half way full, use a lower setting. Keeping the freezer at a mid to low setting all the time should be fine, because its usually the fridge part that gives people trouble.You will have to judge on your own which setting is best (i.e you can tell when its good based on how cold the juice is in there, etc).
By adjusting the setting based on the amount of food in your fridge, it should prevent frosting.
Hope that helps!
Mar 28, 2011 | Kelvinator KBM5100MB
Do you have the manual of the kelvinator washing machine 380 ?
www.diplodocs.com
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 21, 2009 | Washing Machines
Kelvinator 380 fridge
called the experts....all fixed.
problem- flty sensor terminator
Sep 04, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
