Question about Targus Wireless Optical Notebook Mouse PAWM10U
Targus wireless notebook mouse
Does the u s b receiver need to be pluged in at all times
  • shivers Nov 22, 2007
    thanks so much for the answer to my question. i thought it needed to be plugged in and now i know i was right. thanks again
  • 328 Answers
See for Windows, the answer is yes. This is because when Windows detects that the mouse is not connected, it may freeze. Also may not boot up all the way from restart either. You can always get a multi port USB hub if you need more USB ports.
Posted on Nov 20, 2007
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
I have a targus wireless mouse MODEL:AMW1603EU the reciver light does not come on and the mouse light doesnt go of nor does it work.
Did you ensure the ON/OFF Switch is set to ON? Did you also try replacing the batteries, then pressing the connect button on the receiver followed by the connect button on the bottom of the mouse?
Jan 14, 2010 | Targus Wireless Optical Notebook Mouse...
How do i install a targus mouse
Depending on your OS, just use the software provided and then place the batteries in the device and connect it as directed.
Sep 21, 2009 | Targus Wireless Optical Notebook Mouse...
Targus amw15us not working
have you tried to change batteries? low battery will cause your mouse not to connect to the receiver.
Feb 04, 2009 | Targus Wireless Optical Notebook Mouse...
Targus wireless mouse not working
I think my mouse is not moving because one usb is missing. I
have trouble find one usb that can help move my mouse.
Aug 24, 2008 | Targus Wireless Optical Notebook Mouse...
Help mouse problem
Click Here to download the User's Manual. It may just be going into sleep mode.
The Targus Wireless Optical Notebook Mouse features an ergonomic design with built-in power management allowing for travel or everyday desktop use. The physical on/off switch, combined with a touch sensor for sleep mode, enable optimized power management capabilities. The thumb-size USB receiver with 90-degree swivel provides flexibility in limited workspace. The mouse features sensitive optical technology for increased accuracy and ease of use.
Jul 27, 2008 | Targus Wireless Optical Notebook Mouse...
My usb
No you require the targus usb receiver to use it
Jul 24, 2008 | Targus Wireless Optical Notebook Mouse...
My targus wireless mouse
I had this happen to me after reprogramming my tv remote too close to my laptop and mouse. Try resetting the reciever and then the mouse by pushing the reset buttons on each one while they are plugged in ( reciever first, then the mouse ).
Apr 05, 2008 | Targus Wireless Optical Notebook Mouse...
Targus Wireless Optical Notebook Mouse PAWM10U Logo
102 people viewed this question
Top Targus Computers & Internet Experts
J John
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
