Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel gwl11 won't fill with water
Husband thought it was the diverter valve, and replaced it with a brand new one that came today. Washer didn't spin before we got the part. Spinning now, but water wont start to come out/fill the machine. Hoses aren't clogged. We have a stackable that we've been using, and the water comes through the hoses just fine for the other washer when hooked up.
Any suggestions?? Thanks!
gittos73
  • 244 Answers
SOURCE: Fisher & Paykel "clog Problem"
the water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
Posted on Aug 12, 2007
SOURCE: RE: won't drain
I had the same symptoms (washes normally, but won't drain/spin) It would only make a faint hum. I found it fairly easy to lift and tilt back the upper section id by removing the front two screws under the lid. The aggitator came out easily by removing the softener cup and unscrewing the large plastic wingnut inside. The upper plastic shroud came off by carefully removing the eight or so plastic tabs. Once the shroud was off, I could lift out the main wash tub. With the wash tub out, I was able to remove all remaining water from the holding tub with a cup and sponge out all water down into the depression where the pump assembly is located. One screw removed the cover to the pump assembly. Once apart, I found a thin piece of plastic was jamming the pump impeller from spinning. I blew through the drain hose from the back to ensure the drain system was clean. Reassembled in reverse in less than 10 minutes. It worked. Thanks Fixya!!!
Posted on Jan 22, 2008
SOURCE: fisher & paykel waher
thankyou very helpful
Posted on Jul 17, 2008
RescueTech
  • 145 Answers
SOURCE: fisher paykel gwl11
Hi Alan.. usually if there is a problem where the diverter valve is not sensed by the machine control, it will throw a fault code and beep and not complete the cycle. There should be a tech sheet under the control panel. Did you make sure you properly re-connected the two orange wires on your new diverter valve?
I certainly have encountered several over the years where the control stops puting voltage to the diverter in recirculate mode.
If you want to be able to use all the cycles on the machine, then you need a new control board. That is part #420094USP and can be purchased from Fisher Paykel Parts direct;
http://fisherpaykelparts.net/index.php?categoryid=111&productid=26
If you need to do laundry in the meantime, use the PERMA PRESS wash cycle, it should work for you, as that cycle does not use the diverter valve.
Also inspect your water pump and make sure it isnot wet or leaky, as this can cause the machine control to either short out altogether or lose functionality on some cycls such as you are experiencing.
I hope this info is helpful to you.
Posted on Dec 15, 2008
  • 713 Answers
SOURCE: GWL11 fisher & paykel washer draining very slowly
Hi just read your posting.Now when you say it 'catches', what exactly does this mean?Was the pump corroded in any way?After the pump drains for awhile is it hot to touch?Best guess on the fault is pump.But I have seen on a machine, the motor controller being faulty.Is your pump the model with an external fan?Have you or can you borrow an electrical test meter to test the OHMS of the pump windings?Please reply with additional information on the questions and I am sure I can help you further.
Posted on Jul 23, 2010
Fisher Paykel Washer GWL11 - I have replaced the Drain Pump,Pump Hose,Diverter Valve. First test: Diverter was in wrong.Drained,but tub didn't fill orrecirculate. Fixed it. Now ONLY recirculates.
After filling with a small amount of water it will recirculate for a while then fill again to a higher level. To recirculate the divertor has to heat up and expand the operating plunger. It takes a long time to cool & move back to the drain position. You may be advancing from recirculate to drain too quickly. Allow at least 2 minutes before trying to drain water.
Feb 25, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Why won't fisher & paykel gwl11 fill cold water?
If the cold water only comes out at a trickle, you need to replace the valve. I have had to replace the hot and cold water valves on my washer every couple years.
Jul 06, 2014 | Fisher and Paykel GWL11 Top Load Washer
Does it matter which wires goes where on a diverter valve for a Fisher Paykel GWL15 washer?
I thought they could only plug in one way? if not, it shouldn't matter, just keep an eye on it first cycle. it activates the diverter right near the start of a cycle.
Oct 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Water pumps out instead of recirculating?
It's not your wires faulty.
Is the valve installed the right way.
When diverter valve is powered will pump water over bowl.
Your motor controller board may be faulty,
And need diverter driver parts replaced.
Set you machine to Traditional wash only to bypass
Eco active filling that users diverter valve.
Jul 08, 2013 | Fisher and Paykel GWL11 Top Load Washer
Error code 52
Diverter Valve Fault
Remove Diverter Valve (Down near the Pump Under Bowl) Check for Blockages or broken hinge mechanism
Check resistance of wax solenoid on diverter Valve
Resistance Should be between 0.7 - 2.5kohm
POWER OFF PLUG OUT
May 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHER GWL11 WONT FILL TANK
Check your diverter valve is in right and working.
Energized valve, water goes over bowl.
Non Energized valve water goes down the drain.
Feb 12, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher@Paykel washer changed water pump and diverter pump work for 5 min. then stop. Power to washer but no lights on. Someone said check fuse; cannot find fuse.
if no lights r on your display then your control module is proberly faulty. why did u change diverter valve and drain pump? please reply 4 more help.
Apr 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel gwl11
Dec 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
246 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
