I purchased a Korg 168Rc Edit from Sound Tower.com it's basically a visual way of interpreting the Korg 168 Digital Mixer, you are using the MIDI functions to control the MODES, PARAMETERS of the 168. If you go to SoundTower.com you will see the EDIT and the picture will show you what is available, but that's all, how the tools in the tool bar functions, is beyond me. There isn't even a manual to describe the functions. Below are the tools available for use with EDIT. 1. Req Mode (Required Mode) 2. Program Librarian 3. Receive Current Program 4. Send Current Program to 168RC Mixer 5. Effect Configuration 6. Faders 7. Equalizer Setting 8. Group Bus - Master 9. Aux Out Channel 10. Effects 1 & 2 11. Midi Receive (Disable) 12. Toggle Meters Display on 168 Mixer
  • 19,396 Answers
Hi.
I think by now you have understood how to use the Korg 168Rc Edit .
You will need to program it first, then to send the program to the mixer.
I am writing because your problem had been re-posted.
Please let us know if you still need help with the Korg software.
Regards.
Posted on Dec 10, 2009
Unlocking disc for sounds
Probably your best bet is to use a sound editor/library. Move the sounds onto your computer, then into the librarian editor, then from there through midi into your keyboard.
Sep 16, 2017 | Korg Music
I want to record from my Korg M50 to Cubase LE4 on my laptop.
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
Feb 17, 2014 | Korg M50 61-Key Music Workstation Keyboard...
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
My Korg KM - 202 mixer's channal A Fader Has broken, and can't seem to find a replacement.
call korg up and they can replace it for you most likely. i've had two midi surfaces that had issues with keys popping off and they let me return them to them and they sent me a new one. just had to pay shipping.
May 06, 2011 | Audio Players & Recorders
Now frustration has set in as i am trying to get my Yamaha MU5 tone generator and Korg keyboard (Both midi) to link with my new Acer Aspire One D255 N550 netbook which i have loaded with an old version of...
I need to know how it's all hooked up first (IE Korg midi out to Yamaha in, Yamaha thru or out to Chord, USB from chord to Acer.....etc etc. etc.)
Also, see if the instruments can at least talk to each other.
Post a reply here.
Mar 14, 2011 | Acer (54.AA806.001) Sound Card
HI there I'm using a Korg synth with my M audiophile and I have a latency problem, I can access the usb control panel but it doesn't let me change the latency or sample rates can anyone help
the latency is in the sound card.
usually you can set the CPU cache to 512 in a program or synthesizer.
Your Korg softwear may be able to ajust this if it is on your pc. Most PC have the sound card built into the mother board thereby not cutting the performance.
2. You will have to purchase a external sound card for your Audio and midi interface to get the least amount of latency.
The PC cabinet with all it components has a lot of EMI (Electromagnetic interference) that cause some of the latency issues with these device. If you can live with 2ms latency which the human ear can't determine then you can render a acceptable audio and midi setup, The Ableton Live 8 series has a latency setting for the CPU in the program. Download the demo and see if you notice a difference.
Apr 16, 2010 | M-Audio Audiophile USB Audio and MIDI...
How to map ableton live 7 midi channels with mixer korg zero4
I've got setting like that.Sometimes when applying changes to buttons whole window with preferences disappear.Is it normal?Also starting and shutting down ableton takes long.Maybe ableton is corrupt.
This is picture of my settings.
http://img2.pict.com/fc/91/7a/1874839/0/800/p103086228large29.jpg
Oct 28, 2009 | Computers & Internet
No sound
1. plug in some headphones into the jack.
2. connect to an amplifier or external source.
3. connect midi to a midi-compatible device and determine if device receives signal by pressing keys
If #1 or #2 passes, your speakers are bad.
If #1 & #2 fail, but #3 passes, your setting are set so that there is no sound, but the keybourd still recognizes input.
If all three fail, the keys do not send a signal at all, you should replace the keyboard.
Dec 19, 2008 | Korg Pa800 Synthesizer
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Getting midi to register
Your question is very confusing. Try rephrasing it. You should try drawing a diagram with this and uploading it to your question to better explain yourself. If you can't upload it (I know I can through the answer, but I'm not so sure about the question) you can e-mail it to me. My address is johnkennick@yahoo.com , if not just put some more detail into the question and try rephrasing it. I'm not really sure about the details of your system.
Mar 12, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
