Question about HP Photosmart C5580 All-In-One InkJet Printer
Get paper mismatch error.doesn't happen if I just copy,but has started giving paper mismatch everytime I try to copy from computer. I have tried everything suggested in tutorials. It doesn't copy if I just hit "copy" on computer and it doesn't work if I File,Print,etc. I have an olderHP 882 that works fine from the computer.
    President:
  • 2,306 Answers
Clean the sensor on the right side bottom of the carriage assembly with a damp Q-tip. That sensor gets covered with ink and can't see the paper properly. You clean the underside that looks down at the paper as it passes thru...
Posted on Jul 22, 2009
Computer says paper jam in printer but printer will make copies
Welcome to the ever popular-widely experienced world of:
PAPER SIZE MISMATCH!!!
YES! That wonderful world where unbeknownst to you but knownst to us (OK I watch Spaceballs WAY TOO MUCH) When you are sending a print job, somehow the paper size setting has been changed. Either in the printer itself, or in the print properties settings in your OS.
Double-check those paper size settings and try to print. If it still happens, try resetting the print settings in the printer back to factory default. Make sure you print out the printer configuration before resetting in case you need to reinstall those settings.
Nov 06, 2013 | HP PSC 1401 All-In-One Printer
Receiving fax
The error comes, even there is a small bit of paper between the rollers. Kindly check the rollers properly
Sep 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
When i press start button on my Canon Gp225, it doesnt respond.. it dont even give any error msg also.. i tried loading more papers n closed the paper tray properly also.. tht gives proper sound also.. but...
if the start button doesn't responds could be that the microswitch/contact of start button needs to be cleaned/resoldered/changed.
You can try to apply small ammount of wd40 on the edge of start button. In some cases helps as first aid.
Call service!
Hope that helps!!!
Aug 29, 2011 | Office Equipment & Supplies
When I try to line tells me that the paper size mismatch and only takes a copy of the text
Have/had the same problem: Getting "paper size mismatch" on the C4280 status screen, after we got a paper jam. Every time we hit OK and put in paper, Message about "Now printing Alignment page", it feeds through quickly, with nothing printed on the page and reverts back to Paper size mismatch. Finally got rid of the error, not sure how, but now when I try to copy anything, we only get the lower right postion of the document that I'm trying to copy. Printing from the PC seems ok.
Powered off and back on, and it is back to P"now printing alignment page, quick feed through and "paper size mismatch" error. AND
When copying directly from the glass panel,it will only print a quarter of the page -however it prints and coorectly if we print directly from the computer.
The problem is the paper size sensors. Remove the plastic access panel that is for access to the rollers in the back and has 4 rollers on it. There are two papaer sensors attached to the printer circuit board (PCB). The control arm for the sensor is a small plastic piece that extends slightly into the paper path above the PCB. The plastic can be broken when you are removing a paper jam. I stuck a small piece of a match stick in the sensor to keep it open (as though a wider piece of paper was passing throught the printer). I can't switch to smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until after it does the alignment phase.
Dec 16, 2010 | HP PhotoSmart C4280 Laser Printer
Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Mar 11, 2009 | HP DeskJet 5550 InkJet Printer
Paper jam when trying to print envelopes.
You need to make sure that your print sriver setting match the setting on the printer itself.
If setting are changed on the printer itself to envelopes then when you go to print click preferences button on print screen and look for a place to change paper type (usually defaulted to letter size.) Change paper type to envelpoes and click ok. Click ok again on print screen and it should print correctly.
Paper types must be configured the same on the device as well as the print driver installed on the computer.
Hope this helps
TankMurdock
Mar 09, 2009 | HP Photosmart D7260 Printer
Paper Mismatch
the paper type is probably not set to "plain" in the printers menu.
May 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
CLX-3160 image offset or margin shift
Dear
Please contact samsung Call center in your region. fothis type of support.
Apr 20, 2008 | Samsung CLX 3160fn All-In-One Printer
Paper mismatch when recieving a fax
I understand that while receving faxes, you are experiencing with paper mismatch error message.
Please select the paper type as plain paper fromt the front panel of the All-in-One and try to recevie faxes.
Mar 27, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart C5580 All-In-One InkJet Printer Logo
572 people viewed this question
Seeker5211
Seeker5211
