Question about Sony Handycam DCR-TRV7000 Digital-8 Digital Camcorder
Sony 360x I put in tape but the door will not close. Can you help.James
When I eject the cassette the door wont open
Posted on Dec 23, 2010
Tape door will not go down
? 13:13
Jul 9, 2014 - Uploaded by GotNoEvidence
Here is a fix that does not involve disassembling your camcorder, sending to the ... This worked for us when the tape door wouldn't close on our old Sony HDR-HC9. .... is you can use the same method to REMOVE a tape when the tray will not lift! ... Yes yourvideo helped me fix my DCR-HC96 camera.
Sony HDR-HC3 Tape Door Won't Close with C:32
Nov 18, 2015 | Sony Video Cameras
I have a Sony Handycam CCD-TR61. It has worked fine until today. It will not accept a tape. If I close the door without a tape it closes and completely shuts like it is supposed to. But if I put in a tape...
Many times it's a belt slipping. Since the tape isn't pulled into position, it's rewound and the tape ejected. A damaged or mal-adjusted switch could cause this too. The most you can do is blow it out with compressed air to see if that helps. I doubt there are many thing the end user could do.
Oct 29, 2017 | Sony Handycam CCD-TR618E Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Cassette doesn't load and move down into machine
I had the same problem. With the camera on, keep taking the battery off and putting it back on. Start to close the door and then open it. Eventually you should hear it try to move. Keep doing it and it should move down all the way.
Jun 01, 2009 | Sony DCR-HC38 Mini DV Digital Camcorder
Sony Cyber-shot DSC-U30
Sony support may offer parts
but the sure fire option is Gaffer Tape
Aug 20, 2008 | Sony Cyber-Shot DSC-U30 Digital Camera
Sony DCR-TRV340 tape door won't close
close it up with out a tape in it.  Slap the side with the tape door three times.  Open it up and it should work.  Sounds stupid, but it works.  For real.
Jun 27, 2008 | Canon ZR200 Mini DV Digital Camcorder
The tape door will not close. 360x  Can you help    1james3422@bellsouth,net James
I had the same problem with my 360X.
I took the camera apart and found two screws loose that hold the tape carrier to the rest of the chassis. The unfortunate thing is that I had to pretty much disassemble the entire camera to get to those two screws. It's working again. I'm assuming those two loose screws were the problem.
Dec 24, 2007 | Sony Handycam CCD-TRV87 Camcorder
Ejection Door won't Close
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR, VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
May 22, 2007 | Sony Handycam CCD-TRV87 Camcorder
Tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Video Cameras Logo
317 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
