How would I fix this CLICKING sound?
If I turn the breaker on & turn the thermostat off, the air handler still turns on & blows cool. Also if the breaker is on & the thermostat is on, and the system is running, while it's running you can hear a distinctive clicking sound like it wants to turn off or on. It's not the thermostat because I just changed that and I still hear the clicking. I opened up the handler and checked the box that the thermostat is hooked up to and I believe that is where the clicking is coming from. More specifically the relay or whatever it's called on top of the box that is connected to the thermostat. Can someone help me with this?
  • 614 Answers
You have a bad fan relay. You need to get it changed. Is this fan board. If so the intire board has to be changed. Safe side get a service tech to check it out ask for free estimate up front. Russ
Posted on Jul 22, 2009
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Th5320u101 thermostat is flashing cool on and the
1) If the OUTDOOR A/C Condensing Unit is running BUT the indoor AIR HANDLER is NOT running, the problem could be as easy as changing the RUN CAPACITOR which is usually located within very close proximity of your indoor air handler motor. Ensure the ELECTRICAL DISCONNECT SWITCH is "OFF" and change the oval run capacitor (usually a 5 microfarad capacitor). This SHOULD fix your problem.
2) If the OUTDOOR A/C Condensing Unit is NOT running BUT the indoor AIR HANDLER is running, the problem could be as easy as the outdoor unit is not receiving the required 220 Volts AC. Turn the circuit breaker for the A/C Unit OFF and then turn it back ON. Ensure the circuit breaker SNAPS when you turn it to the ON position.
3) If the previous two steps to not apply or do not work, go to the paperwork supplied with the Thermostat. Almost every manufacturer provided a TROUBLESHOOTING GUIDE within their literature. Follow those steps. If their TROUBLESHOOTING GUIDE does NOT fix your problem, they should have a TOLL-FREE TELEPHONE NUMBER provided to contact their TECHNICAL EXPERTS with your problem(s). Call them and ask them what could be causing the problem.
Aug 31, 2014 | Heating & Cooling
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Brand new furnace wont start its a aruf 14 electric air handler with a 10 amp heater coil
the 3 amp fuse protects low voltage side of transformer. if it's blowing on a call for cooling wire pair going to outside unit bad or contactor in outside unit.
Nov 18, 2013 | Goodman Heating & Cooling
Keeps blowing 3 amp fuses when i turn the air conditioning on.
Ok, If 3 amp fuse is blowing in the air handler unit when switch is turned to cool check to see if outside unit jump starts and stops when this happens. If this is the case wiring is fine check main relay in outdoor unit. There will be a spring contact on main relay (Black relay close to where wires come into unit), check for corrosion or carbon build-up on little round contacts. If you can clean contacts with a small piece of sand paper. Make sure all breakers are off before removing cover! You might have to remove relay in order to clean it. Make sure you write down exact locations of any wires you remove. This should fix the problem.
Jun 20, 2012 | Heating & Cooling
When i tunn on my AC unit at the thermostat it blows the 3 amp fuse in the air handler when it call for cool when i switch the t stat to off and just turn fan on the fuse does not blow and blower runs
sounds like the compressor is or a electrical component directly linked with the cooling operation/ outdoor unit running.
Possible short to earth....
cheers
Jul 05, 2010 | Ruud UBHC Air Conditioner
I have a Ruud air-conditioner/heat pump and it blows 5 amp fuse.
It sounds like the thermostat wire going to the condenser is ground, It either got pulled loose and is touching the housing or as in most cases the wire got cut or was chewed by an animal. You need to turn electric off to both devices and physically inspect the thermostat wire going from the air handler to the outside unit, also inspect where they connect inside the unit. When you find the break, cut and strip each individual wire and securely wire nut each conducter red to red white to white and so on. There you go all fixed. That's when I give you the bill for $75...except this time you write that check to yourself. Good Luck
Jul 14, 2009 | Ruud UBHC Air Conditioner
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
Fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Jan 24, 2009 | Heating & Cooling
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
