Question about Garden
Lawn mower won't start
My mother-in-laws boyfriend was mowing are yard and hit a cable wire it wrapped in blade and stopped mower i untagled it and mower started right up about a month later i went to start mower it started then died and i can't get it started. I'v changed sparkplug, new gass 7 even used WD 40 onspot were blade rotates to make sure it was lubed the blade is not bent and nothing is tangled in it but it won't start now any ideas.
Thanks,
Jessica
  • 130 Answers
Sound like timing is off sherd a key in flywheel
take cover off where you pull the rope and then
take off nut off flywheel its going to be tight and hard to get off but can be done take a screwdriver to hold flywheel ones the nut off look around shaft see if flywheel key is sherd
or pry off flywheel be carefull dont damage anything if sherd replace key
Posted on Jul 22, 2009
Troy Bilt Kohler 18hp riding mower won't start.
there is a main fuse . usually hidden in the wiring . contact a dealer for assistance
Oct 07, 2017 | Troy Garden
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
Hi - I have a Yard Machine lawn mower. While mowing, I hit a steel tap and the machine stalled. Now the pull chord can't be pulled and is jammed. What should I check? Please advise
I HAVE SEEN THIS HAPEN SO MANY TIMES,,,,PLEASE TAKE OFF YOUR SPARKPLUG WIRE AND TILT THE MOWER UP AND TURN THE BLADE BY HAND YOU WILL FIND THAT YOUR CRANKSHAFT IS BENT..ITS AN EASY FIX FOR ANY REPAIR SHOP,
Jul 15, 2011 | Garden
My helper was mowing with my Honda push mower.. The handle started shaking.. a lot.. It will start up at first pull but is not cutting well. The blade is turning but the mower is vibrating so much it...
it sounds like the blade may have hit some thing hard .
You say the blade is turning is it turning level or is it sort of swaying as you may have ofset the drive pin.
Worst case.. new mower as it can cost a lot of money to repair drive
I know as i have done the same thing a few years ago
Aug 02, 2010 | Mtd 22" Yard Machine Push Mower
Turn off mower blades the electric clutch spins and the two green
There should be a metal "anchor" that bolts to the chassis or engine. It has a rod that sticks downward, fitting into a notch in the clutch to keep it from turning. It must be missing or broken, or maybe the clutch is the wrong model, and that's why the clutch itself spins and rips out the wires. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
My lawnmower quit mowing.
It depends on whether its a lever or pushbutton engage model? it may be a broken belt or a simple wire connection come loose. If you want to stay friends tell them mowers are repairable/replaceable but friends arent!
Aug 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
