Question about Polaroid FLM-3734B 37 in. LCD HDTV
Sound on tv
The sound on the tv dont work i dont have a surround sound
    Problem Solver:
  • 17 Answers
Check in your menu, and see if the internal speakers are on or off. If off turn them on. Check connectors, and plugs on main, and audio section of the board inside the tv.reseat them,(wiggle). On the back of the tv plug a cable into one of the aux audio inputs, and put the tv on that particular input like video 1, then touch the tip of the cable. If you hear a buzz the audio is working. If that doesn't narrow it down It's time for the shop. Hope this helps, I don't have a manual for this TV.
Posted on Jul 25, 2009
2 Suggested Answers
  • 208 Answers
SOURCE: tv dont work with surround sound
It is important to remember that you will not get digital audio out unless your source into the unit is digital, such as digital tuner or Hi Def cable or sattelite.
Posted on Feb 24, 2008
How do i turn off the surround sound on my tv
Hi, All newer tv's have a menue that you can change settings to.
Audio and video both have parameters to. On your remote go to menue and look for audio settings and in that list should be surround
Click on/off. Hope that helps.
Mar 17, 2014 | Bose Audio Players & Recorders
Connecting sony surround sound system to tv
i had the same problem what i did was conect a optical cable from the tv to my surround sound and hit the viera link button then i was able to change from tv speakers to home theater which automatically turned on my surround system and set it on the right mode to work cool feature now i dont even need all my contro i can turn on my ps3 and surround system with my tv control
Jul 11, 2010 | Panasonic TCP50C2 50 in. TV
Trying to make the sound go to the surround sound
how are you conecting the tv to dvd surround
phono plugs or scart /ero plug? best results are to conect from tv audio out to input on surround i have an older sony and it wont work though the start lead DONT FORGET TO SELECT SOURCE
Mar 04, 2010 | Sony DAV-C770 System
No sound coming through
If the DVD player is seperate from the surround system and hooked up to the tv. You should have a wire from audio out on the tv to the audio in on surround sound. Some tv require you to turn off tv speakers inorder for it to be routed to the audio out. In which case you can do this in the menu.
Mar 14, 2009 | Audio Players & Recorders
Surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
Nov 25, 2008 | Audio Players & Recorders
Tv dont work with surround sound
Feb 20, 2008 | Polaroid FLM-323B Television
Surround sound hook up
av/out on tv to av/in on vcr / av/out on vcr to av/in on home theater pls rank
Jan 23, 2008 | Televison & Video
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Jan 16, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Hi i cant get no sound other than frying inmt rear left and right spearkerall the other is working
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Nov 03, 2007 | Audio Players & Recorders
Polaroid FLM-3734B 37 in. LCD HDTV Logo
107 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
