Question about ASK Proxima Proxima LAMP-021 Replacement Lamp Projector Lamp
Promima pro av 9400+ light dims slightly
Do you know what would cause the lamp on this projector to dim down slightly then come back to full brightness in eratic intervals. thanks Ezra J Mulheron
  • 328 Answers
It may sound like the bulb needs replacing but first you should make sure that the outlet you plug it into has a constant 110 voltage. You may need to buy a voltage regulator to see if that works first. You can try a new outlet too. Sometimes other sources draw electricity from your wall outlet which cause the drop in voltage and poor lighting. Of coarse if that does not work, replacing the bulb would be the next logical solution. If your handy at opening it up, you could test the capacitors and connections for polarity and resistance with an ohm meter. Also check the current in the wall socket for constant voltage.
Posted on Nov 20, 2007
I am told the light is very dim. Is this a sign the lamp is going bad?
From the first moment it is used, the lamp in a projector is losing lumens (a measure of light). Most projectors' lamps are good for 1500 to 2000 hours of use. Even at the halfway point, a significant dimming can be noticed.
If you do not have many hours on the lamp, you may have a defective lamp and should seek some sort of compensation from Mitsubishi or whatever retailer you purchased the projector.
Mar 09, 2011 | Mitsubishi VLT-XL8LP Projector Lamp for...
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
What could the problem if the image is dim when projected
check the lamp first. if the inside has bulges, black spots, or fogging, replace the lamp. if that's ok, clean out the projector with canned air. the dust sticks to some surfaces. if the dust coated the colorwheel and the heat from the lamp baked it on, you'll need to replace the colorwheel. that might be what's making it dim. you could get the parts from an infocus service center and do it yourself, or send it in to them and have them do the repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 15, 2009 | InFocus ASK Proxima M2+ Multimedia...
Image goes Dim
Hi there
Keep in mind that the light will only flicker if the bulb reaches a certain amount of hours or if it is damaged completely.
Try taking out the lamp and check on the inside of the shaft if you see any black vein looking marks on it or if there is a bubble at the bottom of the shaft - this normally causes the lamp to be very dim and will need replacement.
Mar 18, 2008 | Sanyo PLC XU35 Multimedia Projector
Projection is so dim
Hi there
Sounds to me like it is time for a new lamp.
Jan 23, 2008 | HP Digital Projector Vp6120 Multimedia...
Optoma ep 753 will not light
you can just open the lamp and see the condition of the inner tube only. otherwise you have to replace the lamp and run it.
Viren
+919814903739
Nov 17, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
InFocus Proxima UltraLight LS1 LCD Projector
There could be several reasons for this problem.
1. New lamp needed.
2. New lamp did not fix? Could be mirror tunnel behind the color wheel than can collapse causing "dim" light source or dark lines.
3. All items "greyed" out caused when the unit does not sense a source input, ie computer or tv tuner. After connecting to a source, you should be able to go and adjust contrast and/or brightness settings
Oct 01, 2007 | InFocus X1 Multimedia Projector
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
ASK Proxima Proxima LAMP-021 Replacement Lamp Projector Lamp Logo
211 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
