Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Dryier does not Start
I press the start button , and the buzzer sounds , the dryier does not start
  • 691 Answers
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
Posted on Jul 21, 2009
Will not run when start button released
Check user's manual of your unspecified Dryer. If it should run when start button is released.
If you are doing everything correctly, my impression is that your dryir is defective and if you don't understand the mechanics and electronics of your device you should call your friendly dryier repairman
Jul 06, 2015 | Dryers
Elec. clothes dryer turns but won't dry
If dryier is 220 V, phase is burnt out, so it's working on 110V, not enough to heat the air. Check your breaker and electric system or dryier.
Jun 02, 2015 | Dryers
No heat in EH5 dryier
do you get heat when you first start the dryer ? if you do i would replace the coils and check venting , if not i would check the igniter to see if it is broken
Feb 17, 2013 | Kenmore HE5 7.0 cu. ft. Super Capacity Gas...
I start the dryier and wokr for a few minutes and stop and turn on again and stop ang mesage in E1
Hi. I can explain why this has occurred and give proper repair details, as well. I have 30+ yrs in the field of large appliance repair.
Sep 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My hoover washier dryer has stopped heating up. I works ok as a washing machine but the tumble dryier doesnt heat up. It is a hoover vhw654d washier dryier
on all dryers you have a hi and a low relay as well as the heater and in some you even have a run tstat check that you have continuity on each side of each of your relays as well as your heater any of these pieces that does not have continuity would be the one that u wuld replace hope this helps if you are not electrically inclined plz call a technician
Jul 21, 2010 | Hoover Dryers
Where would I find the heating element on my dryier. My dryier stopped heating and I am trying to check the heat element.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 23, 2010 | Whirlpool LEB6300 Electric Dryer
If you don't want to open the case, you can use sprayer, find it in the market, contact cleaner (spray).
Spray the cleaner right into the fan rotor, and to remove the dust, use the paint brush or vacuum cleaner.
Hope it's work!!
Dec 09, 2009 | Maxtor Shared Storage II (S01R320) Hard...
The dryier does not heat
the problem are your gas coils are faulty
Jul 26, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Aug 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
162 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
