Question about Toshiba Tekbright 15" CRT Monitor
Dim monitor everytimt i turn on the computer the screen lights up and then goes dim after 2 to 3 secs but If i look hard i can still see everything on the screen and i just bought a new power supply for it the monitor is a maginnovision
  • 748 Answers
Hi
You just bought a new power supply for the monitor? Did you set the B+ voltage to the correct settings. Rebuilt power supplies for CRT monitors are not set correctly at the factory. Use your schematic to determine the proper B+ and then set this under load.
Thanks
Posted on Jul 24, 2009
Monitor comes on but the screen gets dark after a 3 sec
if the power indicator at the front panel stay lit but no screen display or black screen, it could be a sign of bad power inverter board or screen back light. now to ensure if it was the cause you can do a voltage checking, at this time you will need a digital tester. you need to know if their is a bl_on voltage at the power inverter board around 3-4.4v to turn on the inverter board that supply the back light.if the power inverter board has 12v dc and has bL_ON voltage then the cause will be a bad inverter board. you must check also for a dry joint connector going to back light.
Nov 15, 2012 | ViewSonic VG2030wm LCD Monitor
Screen goes black after 2 sec
The lightbulb high voltage power supply is detecting problem with the low voltage power supply or with one of the light bulbs and shutdowns in emergency. Open the monitor and check for inflated capacitors. Replace all capacitors even if only few are inflated. Light bulbs require further testing empowering them one by one with external high voltage por supply and their replacement is not easy. Have to open the LCD and then it's hard to clean the layers from the dust resulting bad spots on the image. Be careful and good luck.
Apr 08, 2012 | LG Flatron Computers & Internet
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Screen is dimmed for 2-3 secs then it goes black
The fault could be a faulty inverter or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp, if faulty the CCFL lamp can flicker or not light up. The CCFL lamp is a mini fluro lamp, and flicks on and off when faulty especially as it ages.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Oct 01, 2009 | Acer AL2223W 22" LCD Monitor
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
Monitor turns off and is dim
replace pwr inverter board...
replace the video/keyboard as well...
Feb 08, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Monitor goes blank
Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 16, 2006 | Dell E153FPc 15" TFT LCD Flat Panel...
Toshiba Tekbright 15" CRT Monitor Logo
122 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
