Question about Evolis Dualys ID Card Printer Smart Card Contact Station (P/N E3003U)
One side of card looks like it has a stripe smeared off
Whenever I print with my evolis dualys I get a stripe appearing down the middle of one side of my two sided card. It almost looks like the ink has been smeared off by a roller, or isn't being layed down fully in that inch wide area. This is only happening in an area of the card that is all black and only on one side of the card (though both have the same black area in the design). What's causing this and how do I fix it?
    New Friend:
  • 54 Answers
Check for driver settings for both faces of cards
Posted on Aug 29, 2009
  • 42 Answers
Clean the print cartiridge by putting tape on the bottom then removing it. or you can replace the ink cartridge. Hope this will help
Sincerely, Wiz Kenny
Posted on Jul 22, 2009
Evolis dualys 3 out of papper
a) Clean the printer
b) Print
Persistence: Probably sensor of the feeder has a problem.
Always good to restart everything, in case Windows plays tricks on you. ;)
Jan 31, 2013 | Evolis DUALYS 3 ID CARD PRINTER
Evolis tears ribbon
You have to put darkness setting down on your driver.
2 chances: a) you have the headset with too much temperature due to darkness setting, or you are printing a particular color like metallic blue, gray or intense yellow that can make headset hotter.
b) When you say you have just a left side printed, i remembered customers that set the ribbon to 1/2 YMCKO, check it's not your case
Jan 21, 2013 | Evolis DUALYS 3 ID CARD PRINTER
Hi good day, my evolis dualys 3 is sendding me a error, PRINT IS OUT OF PAPAER, and i have the cards there, i was printing ok tthen i turn off and then turn on and i wanted to print but i cant for this...
Just see for a sensor located below feeder . Clean it with brush and blower. Also check for input setting in driver whether it is automatic feeding or manual.
Apr 11, 2011 | Evolis Dualys Thermal Card Printer
I'm using Evolis Pebble 4 to print card, i wish to let the printer flip the card itself and print at the back of the card. So i first set the duplex of the printer to vbPRDPVertical on VB6, and then i...
Dear Sir,
Evolis pebble4 printer is a single side card printer . It doesn't has mechanism to flip the card.
If you want to flip the card automatically you must go for Evolis Dualys or higher model.
Apr 04, 2011 | Evolis PEBBLE 4 Led Card Printer
Ribbon cut when printing a standard test card
Check for ribbon setting in driver. Run self adjustment process
Aug 03, 2010 | Evolis Dualys ID Card Printer Smart Card...
Blurred printing at the x offset
Print head is not aligned properly . You need to adjust heating plate on head.
Aug 02, 2010 | Evolis Dualys ID Card Printer Smart Card...
I have problem with my Evolis Dualys 3 printer printing a line on the card?
Your print head needs to be replaced if it a horizontal line
. Transport belt to be replaced if vertical line
May 06, 2010 | Evolis Pebble 3 ID Card Printer Package...
Fading image...
1.Check for proper driver on evolis site.
2.Check whether both side printing is selected in driver
3.Check for Varnish sensitivity setting in Graphics setting it should be default.
4.Read the ribbon type with Rr command.
Feb 23, 2010 | Evolis Pebble 3 ID Card Printer Package...
The card comes out all in black color why?
Before we start first things first, you DO have the color ribbon installed correct? If so, go to control panel, click Printers and faxes, right click the evolis printer icon, scroll down to properties, open it up, click the graphic tab, then select 6 panels ribbon (YMCKDK) that should do it since I had the same problem.
Dec 21, 2009 | Evolis Dualys Thermal Card Printer
Not printing
Check for black panel setting in printer driver
it should be all black dots ideally and should solve your problem
Jan 02, 2009 | Evolis Dualys Thermal Card Printer
Evolis Dualys ID Card Printer Smart Card Contact Station (P/N E3003U) Logo
185 people viewed this question
Top Evolis Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
