Question about Garden
JD 314 riding mower with pto engaged wires get hot and stops motor from running. It seems to be an electric overdraw problem
    Problem Solver:
  • 12 Answers
I HAVE SEEN INTERNAL PROBLEMS WITH THE CLUTCH ITSELF. COULD BE A WORN BEARING OR THE FRICTION DISKS ARE TOO WORN
Posted on Jul 29, 2009
JD ltr180 stalls when blades engaged
if it has an electric pto for the blades, it is possible that by engaging that pto, there is not sufficient power left to run the engine
check charge rate , battery condition and pto system
Jun 30, 2016 | Garden
Mower won't engage
Riding Mower Electric PTO Clutch Won't Engage When Hot ...
? 7:16
www.youtube.com/watch?v=wH9tZl6GzE0
May 2, 2014 - Uploaded by Steve O Riding Mower Electric PTO Clutch Won't Engage When Hot Fix.
Sep 30, 2015 | Garden
Why can't I engage the mower deck?
? 7:16
May 2, 2014 - Uploaded by Steve O The PTO is relatively easy to change assuming that you can get the bolt out of the crankshaft. Basically follow ...
Sep 09, 2015 | Garden
Pto wiring
Mower Clutch Cable Replacement - Craftsman Riding ...
? 5:37
www.youtube.com/watch?v=pSXOBQojHggAug 22, 2014 - Uploaded by RepairClinic.com All of the information in this clutch cable replacement video is ....Riding Mower Electric PTO Clutch Won't Engage When Hot Problem Fix ...
Aug 05, 2015 | Garden
Electric clutch wont engage when when switched on even though I can hear a clicking sound at the clutch.
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 11, 2015 | Swisher 60" 26 Hp Zero Turn Radius Riding...
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
On a Husqvarna 2005 ELS 2448 riding mower, PTO switch burns up, and wont blow the fuse first? Why?
I used to see this on the Kawaski engine machines with an electric clutch, they put a diode between the two clutch wires so as so as to stop any electrical feed back throught the clutch, when the machine is running without the clutch engaged it can turn into a generator.
Oct 17, 2012 | Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
Part number for JD 314 front electric clutych
At www.jdpc.deere.com, I found 2 part numbers for the electric clutch.
AM38623 is an OGURA clutch and AM34287 is an Warner clutch.
You will have to decide which one is on your mower.
Good Day.
Oct 16, 2009 | John Deere Garden
Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Jun 21, 2009 | Garden
Garden Logo
158 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
