Question about Pelco Televison & Video
How can i hook up my pelco model:PMCL15A MONITOR TO HOOK UP AITH MY DIRECT TV
2 Suggested Answers
SOURCE:
atang1
  • 734 Answers
SOURCE: I have a Sampo monitor/possible LCD, Product Name:
You have to add a desktop computer with a TV card on it to show TV on monitors.
Posted on Nov 29, 2010
Tip
Pelco PMC10A Monitor 10 INCH COLOR HIGH RESOLUTION
We bought 6 Pelco PMC10A Color Monitors and they are working 24 hours a day. Suddenly after the warranty was over, the screen went totally black on 3 of them. After searching a while for the cause, Pelco seems to have used the wrong capacitor on their board close to the fly-back. They used a catalytic capacitor G-LUXON 4.7uf 50v and they have all busted by just looking at it on the board. I replaced the defect capacitor with a 4.7mf/250V Metallized Polyester Film Capacitor for about $2 each. They are now fixed! Hope this will help someone that has the same problem as I did.
REF: http://cgi.ebay.com/4-7mf-250V-Metallizd-Polyester-Film-Capacitor_W0QQitemZ220150073474QQihZ012QQcategoryZ4662QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
on Dec 03, 2007 | Pelco Pel Monitor 12" B/W
I have a Pelco PMCL542A 42" monitor that power RED led is on but screen is black
Lcd tv's Do that when the backlight bulb is out. There should be a small panel on the back. Order a new bulb and replace it and it should work fine.
Dec 05, 2014 | Pelco PEL-PMCL542A-S 42-Inch Liqued...
I have a pelco pmcl319 19" lcd monitor. when i switched it on the power (LEDlit) stays blue but it has no display. hope you have a solution for this. thanks.
First thing I would recommend is to get a flash light and shine on the surface of the screen where the Pelco name normally appears when first turned on. Next press the power button and watch at the center of the display. If you see a gray image of the Pelco name then the ccfl backlighting is no longer functioning. I have been able to order replacement ccfl lamps and if need be inverters that drive those lamps. These part can be purchased from http://www.lcdparts.net/. Disassembly of the LCD display is required as well as some soldering.
Feb 17, 2011 | Pelco 300 SERIES 19 INCH FLAT PANEL LCD...
I have 6 pelco make 5104 dvr connected to a
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Jul 15, 2010 | Pelco Video Recorder
Pelco monitor display is darkening
There is another brightness adjust on the back of the monitor.
Feb 19, 2009 | Pelco Pel Monitor 12" B/W
I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
Camera picture
Let me preface this by my expertise with Pelco Products.....I have been working for Pelco for over 8 years now......So I need to know what the model number of the camera in you DF5 dome is because that Dome Pack number is not a valid part number....Here is how that part number brakes down...the DF5 tells me its a DF5 Dome and the UY is the section of that part number that doesn’t make sense...its not a valid number it should be either a CA ,MA or CC and the 0V21A tells me that it has a smoked bubble with the 13VD2.8-12 vari-focal Auto iris lens...... On a different note we do not make a fixed camera that will fit in a DF5 Dome that can take up to 26-27VDC (Direct Current) So if you are using 26-27 VDC you might have damaged the camera try a 24VAC transformer instead.....Good Luck and the more information you can give to me about the camera that is in the Dome the better.....let me know if this helped..
cbinny1
May 02, 2008 | Pelco DF5UY 0V21A Domepak In Ceiling...
Televison & Video Logo
Top Pelco Televison & Video Experts
Marvin
Marvin
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
