Question about Samsung CLP 300 Laser Printer
Phantom paper jam . Samsung clp300. Flashing red light
Check the waster toner cartridge. The previous owner ditched their clp300 on FREECYCLE (which is a marvelous thing)because they did not find this solution. Apparently the "paper jam" indicator can also indicate a slew of other anomalies:
-The printer is experiencing an error, such as jammed paper, open cover, empty paper, not installated [sic] waste toner container, or ***full waste toner container.***
-The printer is experiencing a service required error, such as LSU error, fuser error, or ITB error. Contact your sales or service representative.
The Waste toner cartridge is largish "L" shaped gray thing to the left of the toner cylinders. The manual says to replace it which is what i did. you may be able to simply dump it out in the trash, but you must wipe off the lenses on it before you re-install.
    President:
  • Samsung Master
  • 1,447 Answers
You clean your printer drum unit wast ink poder drum open and wast ink
Posted on Jul 23, 2009
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
May 11, 2010 | Samsung CLP 300 Laser Printer
My samsung 315 clp has status LED red light on.
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
Dec 14, 2009 | Samsung CLP 315 Laser Printer
Samsung, CLP300. The Printer makes a severe
you may check on this issue by opening the back door, pull out paper tray take out the toner block (OPC) and see is there any paper really cought jam.
next examing the noise is from the front or near the back end.
if is from the front. took out the black toner to confirm is the issue from the black toner.
if from the back. Than it will be your DEV Main drive n Fuser gear has already worn out.
Nov 13, 2009 | Samsung CLP 300 Laser Printer
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Oct 23, 2008 | Brother HL-2040 Laser Printer
Doesn't print
You may need to empty the excess toner bottle, it's in the front, to the left side.
Oct 06, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 won't print
a few seconds after turned on?
after a half hour ?
in the first case it indicates a problem most likely with the fuser.
in the second case it might be on a timer.
Aug 05, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
1,533 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
