Question about Cateye Fitness Cateye Strada Wireless Bike Computer Cc RD300W
Odometer stops working at 33 mph
My odometer work great until I reach a speed of 33 mph. At that point in displays 0 mph. What might be the problem?
  • rmiller250 Jul 22, 2009
    I am not doing the test by spinning the wheel. I'm actually riding the bike when it happens. I don't think it has something to do with the vibration in that it happens nearly everytime at around 33 mph. I would think the vibration happens and even slower speeds. Could it be that my magnet is not strong enough to trigger the signal at faster speeds?
  • 34 Answers
This is a very strange problem indeed. I'm guessing you are doing this test by just spinning the wheel, not actually riding. In any case, make sure the sensor itself is not loose. This could be moving from the vibration at higher speeds. Thanks
Posted on Jul 22, 2009
The odometer is not working on my 1999 navigator. It just says 0. What could be the problem?
Odometer The instrument cluster receives odometer rolling count status from the PCM-engine computer and stores the mileage in non-volatile memory (NVM). When the instrument cluster fails to receive the odometer rolling count status for more than two seconds, the odometer display will show dashes.
HEC Dealer Test Mode
To enter the HEC Dealer Test Mode, depress and hold the instrument cluster SELECT/RESET button and then turn the ignition switch to the RUN position. Continue pressing the SELECT/RESET button (5 seconds) until tESt is displayed in the odometer. The SELECT/RESET button must be released within 3 seconds of the odometer displaying tESt to begin the dealer test mode. Depress the SELECT/RESET button to advance through the following steps until dtc is displayed. Depressing the SELECT/RESET button will display any continuous DTCs stored before proceeding to the next step.
All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster .
Odometer Display Description GAGE Activates gauge sweep of all gauges, then displays present gauge values. Also carries out the checksum tests on ROM and EE. If the gauge sweep is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster . All segments illuminated Illuminates all odometer segments. If any odometer segment is inoperative, INSTALL a new instrument cluster; REFER to Instrument Cluster . bulb Illuminates all micro-controlled lamps and LEDs (low oil pressure/high coolant temperature, low fuel, service engine soon, brake, low range). INSTALL a new bulb or LED as necessary. r Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline). If alternating flashes of FAIL and ROM level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster . EE Displays hexadecimal value for EE level (used when requesting assistance from the hotline). If alternating flashes of FAIL and EE level are displayed, INSTALL a new instrument cluster; refer to Instrument Cluster . dt Displays hexadecimal coding of final manufacturing test date (used when requesting assistance from the hotline). dtc Displays continuous DTCs. Pressing the SELECT/RESET button will display any DTCs stored before proceeding to the next step. enG Displays the English speed in mph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0. m Displays the English speed data (mph) received from the PCM via SCP Network. Displays the metric speed in kph. Speedometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if speed is 0. tAc Displays the tachometer data received from the PCM via the SCP Network. Tachometer will indicate present speed within tolerances. Display will show 0 if input is not received, if input received is invalid for one second or more, or if engine rpm is 0. FUEL Displays the actual A/D fuel level. The fuel gauge will display a filtered fuel level value. This filter will keep the pointer from moving suddenly or erratically. If the value displayed is between 0 and 20, the circuit is shorted. GO to Pinpoint Test D .
  • 255=open send +/-0
  • 232=Full stop +/-10
  • 215=Full mark +/-10
  • 178=3/4 mark +/-8
  • 138=1/2 mark +/-7
  • 93=1/4 mark +/-5
  • 41=E mark +/-4
  • 54="LOW FUEL" (0-59)
  • 0-18=short (0-20 max.)
OIL Displays the code (0-255) for the oil pressure switch input to the HEC. Displays the oil pressure reading input to the HEC. Oil pressure gauge will indicate present oil pressure. Normal oil pressure (greater than 6 psi) will display a value between 000 and 176. A low oil pressure (less than 6 psi) or an inoperative engine oil pressure switch will display a value greater than 176. dEGC Display of engine temperature in Degrees C input from cylinder head temperature sensor. If the value displayed is -40C, the SCP message for engine temperature has not been received for more than 5 seconds. GO to Pinpoint Test E .
  • 49 C="C" mark.
  • 60 C=Normal band start.
  • 120 C=Normal band end.
  • 119 C=Temperature warning indicator ON.
  • "-40" C=No SCP Message for 5 sec.
br Displays the brake fluid level input to the HEC. bAtt Displays the code (0-255) battery voltage input to the HEC. Battery voltage gauge will indicate present battery voltage.
  • 93-102=6.9-9.1 volts (Low voltage)
  • 115-124=8.5-10.7 volts (Norm band start)
  • 215-225=15.8-18 volts (Norm band end)
  • 230-241=16.9-19.1 volts (High voltage)
rhEo Displays the present hexadecimal value for the instrument cluster backlighting pulse width modulated (PWM) input to the HEC (used when requesting assistance from the hotline). rhi
rhS
rho PWM input duty cycle.
SCP hexadecimal dimming step (used when requesting assistance from the hotline).
Output driver counts in hexadecimal format (used when requesting assistance from the hotline). Cr Displays the present RUN/START sense input. Display will show -h with the ignition switch in the START position and -L with the ignition switch in the RUN position. ALtF Displays 8-bit hexadecimal value for alternate fuel level. Display will show a value between 00 and FF if the message is received. PA-PE7 Not used. GAGE Repeats test display cycle.
Turn the ignition switch to the OFF position or press and hold the SELECT/RESET button for 3 or more seconds and release to exit HEC Dealer Test Mode. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Mar 12, 2018 | 1999 Lincoln Navigator
Where are all the ground wires located on a 2008 chevy cobalt?
It wouldn't be a ground problem If it were the whole instrument cluster would be dead . Checking the BCM an the IPC for DTC'S - diagnostic trouble codes is the proper way to diagnose this type problem . Not worrying about grounds .
Odometer
The vehicle odometer is calculated and stored electronically in the body control module (BCM) and is sent via the serial data circuit to the instrument panel cluster (IPC) for display. The BCM calculates and stores the mileage based on the vehicle speed serial data information from the PCM/ECM. The IPC displays the season odometer information from the BCM in the driver information center (DIC). The odometer will display error if the IPC detects an invalid odometer data from the BCM. After an invalid odometer data is received from the BCM, the IPC will display the last known odometer reading for 1.5 seconds before error is displayed in the DIC.
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed based on serial data message from the body control module (BCM). The BCM receives vehicle speed data from the PCM/ECM via the serial data circuit. The speedometer will default to 0 km/h (0 mph) if:
• The PCM/ECM detects a malfunction in the vehicle speed sensor circuit.
• The BCM detects a loss of serial data communications with the PCM/ECM.
• The IPC detects a loss of serial data communications with the BCM.
Your best bet would be to take it to the dealer !
Apr 19, 2017 | 2008 Chevrolet Cobalt
My mph, gas, and temp gauges are not working
That's why you don't let you husband work on your car ! Unless he does it for a living .. For MPH there is a VSS - vehicle speed sensor , for the gas there is a sending unit in the fuel tank, for the temp. gauge there is a temp. sensor located in coolant stream on the engine .You more then likely need to have you instrument cluster repaired . GM had a problem with step motors inside the instrument cluster . A step motor is what controls the individual gauge. The sensors are all inputs to the PCM - powertrain control module (engine computer ) .
Engine Coolant Temperature Gage
The IPC displays the engine coolant temperature as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine coolant temperature. The engine coolant temperature gage defaults to C or below if:
The PCM detects a malfunction in the engine coolant temperature sensor circuit.
The IPC detects a loss of class 2 communications with the PCM.
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gage defaults to empty if:
The PCM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than 14% (84ohms), the low fuel indicator illuminates.
Odometer
The IPC contains a season odometer and a trip odometer. Momentarily press the trip select/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip select/reset switch for greater than 1.5 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the IPC. The IPC calculates the mileage based on the vehicle speed information from the PCM. The odometer will display 'error' if an internal IPC memory failure is detected.
PRNDL Display
The IPC displays the selected gear position as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the gear position. The PRNDL display shall flash all gear positions if:
The PCM detects a malfunction in the transmission range switch circuit.
Speedometer
The IPC displays the vehicle speed based on the information from the PCM. The PCM converts the data from the vehicle speed sensor to a 4000 pulses per mile signal. The IPC uses the vehicle speed signal circuit from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 mph (0 kph) if a malfunction in the vehicle speed sensor circuit exists.
Tachometer
The IPC displays the engine speed as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine speed. The tachometer will default to 0 rpm if:
The PCM detects a malfunction in the engine speed sensor circuit.
May 22, 2016 | 2002 Buick Century
Why speedometer not working aveo
we need year.!
and if odometer is dead too. not working means ? 0 mph at all speeds? (legal)
check fuses yet?
does the check engine light come on key on, and go out driving,
if the CEL sticks on running there IS A PROBLEM.
scan the PCM, best practice is to scan always.
Sig: I must ask questions first, I'm blind, and my tools can't reach, dig?
Jun 22, 2014 | Chevrolet Aveo Cars & Trucks
1986 Alfa Romeo Spyder. WHen stopped, speedometer shows about 12 mph. At highway speed, it shows about 20 mph. Odomater seems fine.
Phylspilot, my 86 Spider never displayed less than 10 mph. If you look closely, you should see a tiny pin that the needle touches at about 10 mph. That prevents it from ever falling to zero. The needle will not move up until the speed exceeds 10. From my experience, that is normal. In your case, not displaying >20 is NOT normal.
The problem could be a few different things. Since the odometer appears to be working ok (I assume you checked that it racks up the miles at a rate commensurate with your approx speed), the speed needle may be sticking. I had the opposite problem with mine - speed needle okay, and odometer messed up.
I recommend pulling the speedometer housing out of the dash and checking to see if anything is causing the needle to bind. If it isn't, then check the fine spring where the needle is attached to ensure the spring is okay. You should be able to move the needle with your finger smoothly and have it return gently to the start position (in your case 12 mph).
This is a tricky operation. If you remove the needle from the stem, carefully place it back on the stem. Do this without moving the stem. Just reinsert the speed needle on the stem exactly at the small pin that holds the pin at about 10 mph.
Check the entire speedometer housing for cracks. Any crack could be enough to prevent proper operation. (That was the source of my odometer issue.)
Have fun putting it all back together.
Mar 20, 2013 | 1986 Alfa Romeo Spider
Changing dashboard light
This solution will be of great help to you,even in the case of future or other dashboard problems;
Instrument cluster consists of electronic analog gauges, various warning lights, and optional tachometer. Vehicles equipped with tachometer have an electronic vacuum fluorescent transmission range indicator (PRND3L),odometer and trip odometer display. Vehicles without tachometer are equipped with a cable-operated transmission range indicator.
Instrument cluster is equipped with the following warning lights:
Battery voltage.
Cruise (speed control).
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Low windshield and washer level.
Traction Control.
The Body Control Module (BCM), which receives input from various sensors, sends display information to instrument cluster and operates gauges. Instrument cluster incorporates a self-test diagnostic feature to identify electronic problems. BCM, Powertrain Control Module (PCM), and Transmission Control Module (TCM) are continuously monitored by the diagnostic system.
SELF-DIAGNOSTICS
With ignition off, press and hold TRIP and RESET buttons while turning ignition switch to ON position. Continue to hold TRIP and RESET buttons until odometer window displays CODE (approximately 5 seconds). If problem exists, system will display diagnostic trouble codes. See DIAGNOSTIC CODE CHART table. If no problem exists, Code 999 (end test) will be displayed.
CodeDescription
110.......Cluster Memory Fault
111.......Cluster Calibration Fault
905.......No CCD Bus Message From TCM
921.......Odometer Fault From BCM
940.......No CCD Bus Message From PCM
After diagnostic code display ends, instrument cluster will go into each of the following tests in order:
Dim test.
Calibration test.
Odometer segment test.
Electronic Transmission Range indicator segment test.
Dim Test
CHEC-0 will be displayed in odometer window. Instrument cluster will dim Vacuum Florescent (VF) display. If VF displays do not dim, a problem in instrument cluster exists. See BODY CONTROL COMPUTER TESTS in BODY CONTROL COMPUTER article.
Calibration Test
CHEC-1 will be displayed in odometer window. Each of instrument cluster gauges will move sequentially through each calibration point. See GAUGE CALIBRATIONS table. If gauge needle is not calibrated properly, a problem in instrument cluster exists.
Odometer Segment Test
CHEC-2 will be displayed in odometer window. Each segment of odometer will light sequentially. If any segment does not light, replace instrument cluster.
Electronic Transmission Range Indicator Segment Test
CHEC-3 will be displayed in odometer window. Each segment of electronic transmission range indicator will light sequentially. If any segment does not light, replace instrument cluster.
Aug 09, 2010 | 1998 Plymouth Voyager
I have a 91 Saturn Sl 2. The odometer spins twice as fast as it should when driving under 55 mph. over 55 it stops working altogether untill you speed up to over 65mph then it spins fast again. The speedo...
its sounds like odometer is bad,,you either gotta get a used one or send it out to get it fixed, i dont think you can get a new one from saturn anymore,too old
Oct 09, 2009 | 1993 Saturn SL2
While driving the speedometer and odometer quit working.
you have a problem with your speed sensor, you need to check or replace it.
Apr 28, 2009 | 2002 Kia Sedona
Cateye Fitness Cateye Strada Wireless Bike Computer Cc RD300W Logo
307 people viewed this question
Top Cateye Fitness Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cateye Fitness Cycling Expert? Answer questions, earn points and help others
