Question about DFI AD77 Infinity Motherboard
Sata drivers do not work with AD77 infinity when installing windows xp pro, it says cannot copy file HTP371.sys
  • Steve Brown
    Steve Brown May 11, 2010
    go to the manufacturers website and download the correct drivers. if you have 64 bit pro you will need a 64 bit driver
    Sergeant:
  • 449 Answers
Try installing the SATA drivers, It is possible your SATA drive need drivers.
Posted on Jul 23, 2009
Need a sound driver for Microsoft Windows Vista,
Need to go to vendors site (Mobo) and download drivers for it. Instal mobo one first.
May 10, 2010 | DFI AD77 Pro Motherboard
I have upgraded to windows 7. I cannot use the
“To install, and Update Hardware, click to open "Computer” from the “Desktop”, check to see if there is a DVD-RW Drive (D :), for external different (E or F:).
I. Look in the “Device with Removable Storage area,” see if the device is present, if so? Do the following: to “setup” the ('player') for “Installation.”
II. Right click on (DVD) “Media Player” select (“Install”) follow all instructions thereafter.
III. If the area is (Blank?), “go to,” and 'click' on the "Start button" click all “Programs” scroll for a Media Disk Player”, open, and do the (“same as above”) for the installation. *Note: “Do the same for “Setup” (above) “Install.”
“If this solution helped, ratings it is appreciated, thanks.”
May 02, 2010 | DFI AD77 Infinity Motherboard
Acer Desktop Veritron M460 will not load Windows XP or Vista!
This problem may occur if the Ntfs.sys file is missing or becomes corrupted when you convert your hard disk to NTFS To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, anddrive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.I hope this helps.The other thing I can think of is maybe your harddrive needs a raid driver.If this is a sata drive and an old version of you os,the sata driver may not be already on the disk and you will have to insert one.Let me know if the first solution works,if not we can try the raid driver.
Apr 08, 2010 | Acer Veriton M460 Micro Tower Core 2 DUO...
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Pci.sys
ya you can transfer that file but it is difficult as usual... you need to some dos and using this dos windows you can copied that file into your c: drive...
but i suggest try to repair with any xp cd
Mar 30, 2009 | Toshiba Satellite 4300 Notebook
CANT GET WINDOWS XP PRO TO COPY FILES TO A GX280
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
TARGA TRAVELLER 1591 TRYING TO DUAL BOOT ITS GOT VISTA I WANT TO INSTALL XP PRO BUT XP CANNOT SEE THE HD IT NEEDS THE DRIVERS. HOW DO I INSTALL THE DRIVERS FOR A SATA DRIVE INTO MY XP INSTALLATION CD
OK I managed to install XP on Targa Traveller on 1591!
With the CD of window XP it is necessary to make F6 for the starting up of the installation and to use a diskette with the pilots(drivers) SATA of NVidia nforce. Naturally the most practical are of incorporated the pilots(drivers) SATA into the CD Windows but I knew how to make;) link for the pilots(drivers) SATA:
Http://garlon.free.fr/Appli/NVidia /
If after the intallation of the pilots(drivers) at the beginning of the copies of file An error of copy of file (cann' t copy spin NVr dll) make Esc (65 files nvidia not copied) and continue the installation up to the restart.
I put out(switched off) the computer, removed the hard disk to put it in an external box usb on another computer I have to copy files dll to System32 or system32 / drivers, file .inf on file windows/inf and file .sys on system 32 or system32 / drivers
I restarted the computer and finished the installation links Pilots(Drivers) xp (I am not sure for Chipset drivers Chipset...you must verify)
http://fred.garlon.free.fr/Appli/Targa
Good luck
Sep 26, 2008 | NEC PowerMate VL3 (ND361799406) PC Desktop
Thomas
It should be on the driver cd that came with your main board,, If you need it to install windows, there is a readme file in the SATA/Raid Folder which contain the instruction for putting it on a floppy disc, basically it involves copying the .sys , inf files to the floppy,, The folder to be copied is named floppy
If you dont have the cd consider using Vista or MCE these have sata drivers built into them
Jul 12, 2008 | Microsoft Windows XP Professional With...
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Sata hdd cant install
hi
go to your bios setup
go to advanced option your sata hdd is disable enable it.
if it is enable then boot your sys with bootable disk
go to dos mode.
type FDISK
Y
4 TO DISPLAY INFO OYUR PARTITION.
IF YOUR PARTITION ARE NON DOSE DELETE IT
THEN RESTART YOUR SYS.
U CAN INSTALL XP NOW.
Mar 25, 2008 | Mercury KVM800M Motherboard
DFI AD77 Infinity Motherboard Logo
542 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Matthew Spark
Matthew Spark
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
