This is my 4th in less than 6 months... About to go get my 5th today hopefully. So many different issues, but this time around the OK button only works on occasion and phone shuts itself off randomly. Also have had tons of problems with the chargers.
Sounds like the "set point" is set too low. If they are sending out same Tech every time... Well get a different guy. This should not be happening something is defective it's new you should have MFG warranty contact them to send out new tech. Hope I helped
run fault codes to check for faulty sensors. Batteries have no specific life span and 1 day to 4 years is any time that they can fail in. Have the battery load tested to ensure that all cells are ok
personally, due to the legal issues involved in working with freon or suva(r-134a) i would recomend tacking your car to a shop licensed for ac repair, if your smelling the oil in the car i would say it sounds like a leak around the evaperator. i hate to be the bearer of bad news, but this can be a pricey problem to fix, but its better than the jail time and fines that can be associated with doing it improperly. sorry i couldnt have better news
Batteries can go bad in less than 6 months. Have it tested again. Also make sure your battery terminals are not dirty, loose, or corroded.
Hope this helps:)
This vehicle is under warranty including towing. There is probably a malfunction within the fuel delivery or ignition system of the vehicle. Sometimes electronic items break down hot,then start working again once cooled.I would let GM take care of this matter under factory warranty
ok. our machine has done this for 6 months or so, it was ok for the 1st 6 months. i have checked and cleaned and unblocked and gone bloody crazy. today i found the fault and fixed quickly.
the installer stuffed up. the waster water hose must head up and be fixed just under your bench top, then come down hill to your exit/spiggot/drain attachment.
ours was just lying more or less at floor level coming up to the spiggot. so whenever the waste water pump switched off, water would run back into the machine, hence the OE error, and also dirty water with food would then get chucked around it what should have been a clean rinse.
a diagram of the waste water house and how it should be done is in the manual.
No, dont throw it away!!! You can use tin foil as a lid - I do this all the time as my lid shattered too and it works perfectly. You dont have to adjust times or anything.
