Kyocera Cell
factory reset
Patrick, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
nice phone
try this link a 95 page pdf should have an answer
page 85
Factory Data Reset 1. From the Home screen, tap Apps > Settings > Backup & reset. 2. Tap Factory data reset. 3. Read the factory data reset information, select the Erase SD card check box if necessary, and tap RESET PHONE. 4. Tap ERASE EVERYTHING. Note: The deleted data CANNOT be retrieved.
you can open the command center of the printer, login using the password admin00. Then go to tab "Basic", click Reset and choose the last one, which says Reset Entire Device To Factory Defaults.
If you just want to reset the frpo parameters to factory defaults, then use the command !R! FRPO INIT; EXIT;
Try to reset the printer.
Factory reset on Kyocera FS-3800 printer: Connect the printer via paralell and type the following in at the command prompt: ECHO !R! FRPO INIT; EXIT;
