Dishwashers Logo
Is my Kenmore dishwasher on the recall list? - Kenmore Dishwashers
Leaking around heating element posts that protrude through dishwasher body
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
www.geappliances.com/products/recall
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
2answers
It won't turn on...the buttons won't even light up
Hi there is possibly a recall on this unit, if you give me full model and serial i can check for you to be certain, but if there is a recall you will want to turn the power off to this unit and call GE service for them to fix it and they can also fix your other problem, but its possibly related to the recall. Let me know.
Sean
9helpful
3answers
Our Kenmore Dishwasher caught fire.
You may want to contact Sears to see if there was a recall on your model dishwasher. There were problems with the door assemblies on some model dishwashers that were caused by the rinse agent leaking into the wire harness of the door. Over time the rinse agent would corrode the wire insulation causing the units to catch fire in some cases. The fix was a free inner door and wiring harness upgrade kit from the manufacturer. Here is a link you can refer to that may offer some assistance:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07190.html
Although I did not see your model number listed, you may want to call the Consumer Product Safety Commission number listed at the bottom of the page and report this incident.
I hope this offers some assistance to you.
Has there been a recall on the Kenmore H3 washer or dryer?
any recall issue will be available on the website for the machine i.e. www.kenmore.com or on the consumer reports website. From this listing I cannot see a recall for this particular machine
1helpful
Racks rusting and falling apart
Do not know about a recal. But you can buy the racks at your local Sears service senter or on line at www.Sears.com
1helpful
Dishwasher Non functioning
Disconnect power immediately! Several brands of dishwashers have had safety recalls over the past few years with bad switches or the rinse aid liquid leaking inside doors or inner insulation reacting with the wirering's insulation, in some cases causing fires. If you google dishwasher recall you will see GE, Maytag, Whirlpool/ Kenmore...... When you search or enter model numbers make sure you use complete model and serial numbers. If you leave off a letter or get one wrong the sites might tell you your model is not involved in the recall. I wish I was on my work computer now,... I'd include some photos of dishwashers which I serviced which did burn. Please leave a comment with your model and serial number.
Aug 31, 2008 • Dishwashers
Concerning recall due to fire hazard. Kenmore model # 36315561790 serial # AT313271R
Go to the GE web site and look. If your model and serial # are listed they will send you a rebate form. This is good for up to $300 off a new dishwasher. If a fairly new model they will send a repair person to fix it for you at no charge. The fire hazare is caused by rinse agent leaking onto the wiring. If you have never used Jet dry or a similar product don't worry. It won't affect you. You can still get the dishwasher fixed free.
Recall on like Dishwasher--when they repaired mine I think the put in bad part
There was a recall on certain models of Kenmore dishwashers. This recall was to replace the heating element. If it lasted a year it is possible that the element could have went bad again, but not likely. There are several things that can cause the thermal fuse to blow. I would recommend having and authorized repair company take a look at it for you as the part they installed over a year ago would no longer be under warranty.
I hope this helps.
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
