Question about GoVideo DVD-VCR Combo
L.G dvd/vcr sorround system
The sound is ok but when I go to av1 it makes a humming noise
  • 979 Answers
Incorrect connections somewhere...accordianman
Posted on Nov 26, 2007
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Dec 30, 2015 | Magnavox Televison & Video
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
Humming noise through Tv speakers. Goes away if I mute sound?
If the noise is coming in through the onboard tuner then repair may the only option. If you have a DVD or VCR and can connect the line level inputs (look like stereo connections) then do so and use that input, if the sound persists there then it is likely the audio circuitry - also a repair item.
Bypassing the TV sound system involves connecting your cable box, DVD or VCR (using the tuner from that unit select channels) audio output to a stereo system and then the TV becomes a big monitor (picture only)
Jan 03, 2010 | Polaroid FLM-3732 Television
No sound from Surround speakers of my onkyo reciever
Check speaker wireing make sure all positive and negative connections are correct. What cable are you running from tv or DVD player.check to see that wireing is correct on receiver for sorround speakers. Run audysee sound calibrator set up. Make sure correct settings for sorround sound in bluray player/DVD player
Sep 13, 2009 | Onkyo HT-S990THX System
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
How do i connect this vcr to a dvd recorder?
Take a scart cable & connect it from the VCR to AV1 on the DVD recorder. Then when you want to record from the VCR select either AV1 /EXT.1/ AUX1 on the DVD recorder as your choice of input source.It depends on the make of your DVD as to determine how the manufacturer has named this inout.
Jun 26, 2009 | Mitsubishi HS-U448 VCR
Connecting a DVD/VCR combo to LCD TV
The best suggestion I would advise is to buy a shielded scart connector & connect that from your DVD combi to either AV1 OR AV2. It sounds as if you are picking up RF interference from your current connections, this can sometimes happen if the cables do not have adequate shielding.
May 21, 2009 | LG 42LG30 42 in. LCD HDTV
Humming noise when Dvd plays
the motor that's spinning the dvd is bad. sorry you have to buy a new one if you don't want to hear the noise. hope this help
Dec 17, 2008 | Coby DVD-937 5.1 Channel DVD...
Hooking up my dvd/vcr playing
The problem definitely lies in your connections. Make sure that the red is in red, white in white and yellow in yellow. If you have multiple sets of these to plug into on the back of your TV, then make sure that look at what that row is named (e.g. AV1, COMP 1, etc...).
Next, change the input on the TV (w/ the remote) to that name: AV1, COMP 1, etc...)
Mar 25, 2008 | Philips Magnavox DVD/VCR Dual Player
Is there a channel to go to when you want to watch from a dvd player?
The VCR will most likely see the DVD player on AV1 try and find a button marked "input" or "av" on either the universal remote or on the VCR itself.
Jan 13, 2008 | Toshiba W627 VCR
GoVideo DVD-VCR Combo Logo
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
