Question about Jensen VM9510 Car DVD Player
Head Units Turns On For 5 Sec.
I've had this in my truck for about 15 months now and all of a sudden once i turn the truck on it beeps like normal and then powers down after about 5 seconds.
    Scholar:
  • 129 Answers
A cd cleaner will not help you..You have a bad processor, junk the unit.
Posted on Aug 07, 2009
    President:
  • 2,976 Answers
Run a good cd/dvd cleaner in it. The type that looks like a disc with brushes on it. It probably has dirt on the lens and can't recognize the disk.
Posted on Jul 21, 2009
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Dell inspiron 15 beeps 7 times
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 23, 2012 | Dell Inspiron 15 Laptop Computer- Intel...
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
My unit, Kiddi Smoke Alarm Model i12040, beeps once every minute. I've checked the battery and it's above 10v. This is a new unit (date June 2010). I've unplugged the unit, plugged it back...
Have you tried a different battery? Occasionally a battery can read good but die under load. Also use care when replacing the battery. Many devices today specify in small print to leave the battery out for a minimum time period (anywhere from about 15 sec to 5 min, depending on the model). Also, it is sometimes quite easy to reverse the polarity on some of these devices. If all else fails, contact the manufacturer. It's possible the unit itself is bad.
Aug 30, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
Both units are switched on but the parents' unit doesn't want to connect with the nursery unit. I clearly see the nursery unit's green light that flashed to detect movement and don't understand why my...
I have the same problem. I'm guessing mine is broken and will need to be replaced. However i did read a possible solution on a site with slightly different instructions to the ones in the box that describes how to pair the two devices together.
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
the parent unit waits for the signal then pairs.
if the nursery unit just waits 20 seconds then beep beep beeps and turns off i guess yours is broken too. I think its probably the nursery unit has stopped transmitting.
they will replace or repair a unit that less than 12 months from date of purchase with a supporting receipt.
the help line is 0845 009 1789 mon-fri 11-3pm
May 20, 2010 | Angelcare Baby Movement and Sound Monitor...
ATTACK OF THE 25 BEEPS!!!!
The airbag malfunction indicator light on the instrument cluster might be the culprit. Turn on the ignition key check whether the airbag light if present. The airbag light shld be on for about 6 sec then turns off if there are no faults found. If the bulb is busted the beeping sound will warn the driver for five consecutive beeps. wear your seatbelts also.
Feb 02, 2010 | 2005 Ford Five Hundred
Camera wont turn on even with fresh batteries
camera wont turn on even with fresh batteries,it says:"battery low..than beep,beep and turn off"
Jan 21, 2010 | Kodak Easyshare C813 Digital Camera
Turns on scan and then just stops
i have a jetta 2000 ... 2.0 am facing problems with my speedometer which is suddenly indicating 240 km then going back to normal speed, once i press hard on the gas when ever the indicator reach max speed while am driving at 100 km hour the engine stops . also lately the engine would start for 30 sec and turns off, i by passed the car to a scanner it show i got a problem with the speed sensor, also sometimes while driving in up the hills the transmission starts getting weird , as if the gear box is sliding a big, then when turned off and on agian everything goes back to normal
Dec 03, 2009 | Medion M3 Composer 5100 PC Desktop
My DS touch screen flashes once when the power switch is flipped, then turns off.
when the ds turn off right after being powered on, that generally would mean the that the ribbon cable that goes from the top to the bottom is either disconnected, or ripped. thats like a $15-$20 fix or so when u get the parts.
Dec 27, 2007 | Nintendo DS Console
Jensen VM9510 Car DVD Player Logo
155 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
