Question about ASUS A8N-SLI Deluxe Motherboard
A8N-SLI Deluxe asus motherboard wont boot
I have an A8N-SLI Deluxe mother board i ran it for 1-2 year no problems and then one day it shuts down wont boot back up i pulled the side of the case off and then started in i checked all the connectors nothin thought maybe the gphx card died bought an new one i currenty have 1 stick kingston kvr/1gr in it not sure of the processor but the comp did work for awhile shut down couldnt boot i get no beeps nothing on the screen so i let it sit for awhile i went back to it blew off some dust cleaned it up and it worked ? worked for about 3-4 months then shut down doing the same thing i have no clue what could be wrong i hope you can help thanks in advance
  • 37 Answers
You are correct that brand of motherboard from Asus do have some problems, I have the exact board now and sometimes those crazy things happens to me, my fan is not working for over a year now and their is no solution but to buy another board base on research that I have done. Plus Asus don't support those boards any more. So if it is the board you better of buying a new one. But also important is to check your Hard drive, Ram and Graphics card because those can be the problem also. I had Ram and HD problems before that was doing the say thing that you explained. I hope this helps also their is software from asus that you can use to check the status of the motherboard most likely it will tell you if the board is going bad, I think it is(please vote/rate me)
Posted on Jul 21, 2009
  • 201 Answers
First you want to make sure
the power supply works, they can stay on for a week then die, then work again , then die
then disconnect the cd rom, and see if it still has the same problem,
next could be the processor , this would be the cheapest part next in line,
processors get warm when they work
if not , you would replace that before motherboard
you can also disconnect the hard drive a while
to make sure there are no config errors
Wont transmit to monitor
Try a different video card frist off,make sure card is seeted in slot good,and check connectors to monitor and board...Cheers
Nov 28, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Boot usb cdrom a8n sli deluxe
Press Deleate key at boot enter bios goto boot settings set 1st boot devise as usb press F10 and enter to save changes
Nov 14, 2009 | ASUS A8N-SLI Deluxe Motherboard
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Its sudenly shut down and not coming back again only fan is working
Try resetting the CMOS, to get the procedures on how it's done on your PC's motherboard, please refer to the image below.
Please reply if this has helped you. Thanks.
Oct 24, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
System boot problem
This is possibly a bad hard drive. If you know the manufacturer of your hard drive you can download diagnostic tools from their site, burn to cd and run diagnostics to check the drive for errors or failure.
Apr 11, 2009 | ASUS A8N-SLI Premium Motherboard
ASUS EZ-PLUG not plugged in?
ASUS EZ_PLUG is optional for SLI mode...this model of your motherboard has an SLI that connect 2 video card using pci express...if this is only you problem for bugging the EZ_plug not connected,you can disable that in BIOS setup...
Oct 28, 2008 | ASUS A8N-SLI Deluxe Motherboard
Ram problems
Your memory should be in slots A-1 & B-1
You Asus board uses the Award bios. The link posted below will tell you what your beeps are saying.
http://www.bioscentral.com/beepcodes/awardbeep.htm
In your case do as I suggested above. I have two working
A8N-SLI Deluxe boards & the memory works fine in A-1 & B-1 slots.
Good luck & best wishes!
please vote.............................
Mar 14, 2008 | ASUS A8N-SLI Deluxe Motherboard
Memory problem.
Check your manual pg. 2-12. Qualified Vendors List. The QVL is tested memory for your board. There was a small fix to memory with bios version 1015. Go to Asus web site for information regarding this update & others. http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 01, 2008 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
251 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
