Question about Canon Pixma MX922
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
SOURCE:
SOURCE: Alarm light on, Display indicates error message: Check Ink U150 M
I added my post today with the same problem, and thought I'd share what I since learned. Apparently this "Alarm light/U150" is common with several Canon models. The U150 indicates a faulty electronic chip (on the ink cartridge). Though I tried cleaning the sensor with isopropyl alcohol, and also tried removing all the cartridges, unplugging the printer for 45 seconds, then reconnecting,etc. as I had read might help, I still had the same frustrating problem. Contacting Canon was the solution that worked for me. First I emailed, but decided I didn't want to wait for their response. A call to Canon Tech Support (1-800-385-2155) was quick and painless. They will more than likely send you a new cartridge, but you'll need to have your serial # & date of purchase handy.
Posted on Dec 11, 2007
SOURCE: MY Canon Pixma MP 500 Printer won't Print.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  5. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  6. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
  7. clear any paper jam
  8. May be your product requires repair service.
Posted on Apr 03, 2008
SOURCE: Prints Blank Pages
I've tried everything before for months... unplugging, new cartridges, servicing, etc. I've always avoided jarring an electronic item, but hitting the front fixed it! A couple of open-palmed smacks above the paper drawer, and it printed this very page. Apparently, sometimes the cover over the laser sticks shut after replacing the print cartridge, or removing a paper jam. Sounds crazy, but smack it!
Posted on Jun 16, 2008
Danieldesmon
  • 56 Answers
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Posted on Mar 01, 2010
F Victor man
  • 846 Answers
SOURCE: Hi I recently had an error on my printer 5 blinks
Oh dear you have suffered what is probably the worst that can happen to this machine. When your original print head failed it took out the logic board with it. They should have been replaced as a pair at the same time. thats what we (canon engineers) do. Fortunately the logic board is not to expensive . The logic board part number is QM3-2738.
Good luck.
PS. I take no responsibilty if the logic board does not cure as although the print head works in another machine it may not in this one. Srri
Posted on Aug 17, 2011
Canon MX922 printer: cyan was okay after installing new cartridge, but quit printing blue after a few days. Multiple deep cleanings were no help. Can print head be removed?
You better buy a new cartridge, or you could fix that open the cartridge on your printer device.remove the cartridge and broom with a Kleenex.If you need the driverpleasehere Canon PIXMA MX922
Mar 20, 2017 | Canon Pixma MX922
Canon PIXMA MX922 won't print black text
Is it out of color ink? It will not print true black if you do not have ALL print cartridges working.
Jul 10, 2016 | Canon Office Equipment & Supplies
How do I know which ink cartridge is Empty on my Canon MX922 printer?
It's the blinking one! You should also get a message on the screen and the 'empty' cartridge should have a cross or exclamation mark on top of it.
Feb 27, 2015 | Canon PIXMA MX922 Wireless InkJet MFC /...
Im trying to print an email off of yahoo and i get low ink for black and i just refilled the ink but the page comes out black and doesnt print tried other ways to print and still get blank page when the...
the ink cartridge is clogged.
somehow during your refill process, air bubbles get in the cartridges.. it is always advisable to pump out the air bubbles using the syringe.
to unclog your cartridge, what you need to do is mix an ammonia with water and soak the cartridge and leave it over night. The next morning after you install the cartridge to the printer, it will print again.
Mar 21, 2011 | Canon PIXMA MX310 All-In-One Printer
The printing is running normally but the paper is coming out blank, no light , no codes. I run the power cleaning 3 times already, can you tell me what to do?
Remove the cartridges and hold a piece of tissue paper under the jets to **** ink through them. If this does not work, stand the cartridges in about 1/4 inch hot water for a while to soften dried ink. (if they are new cartridges, did you remember to remove the seal over the jets?)
Jan 24, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Printing but blank pages coming out .
Take the ink cartridge out of the printer. On the bottom of the cartridge, there's a copper/gold surface with bumps and holes. Take a napkin or peice of paper and rub it on this surface. This serves two purposes - if there's any dried ink or blockage, it will help clean it, and it's a test to see if there's any ink left in the cartridge. On a normal ink cartridge, rubbing paper on the bottom would cause some ink to smear onto the paper. If nothing wet comes out, the ink cartridge is dried out or empty. You'll need to replace it.
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Nov 29, 2008 | Lexmark X5150 All-In-One InkJet Printer
Blank paper
That is the most likely cause.
Also under the cartridges, there are some ports and pads that may have dried out. In that case unplug the machine, and remove the cartridges, trickle some alcohol slowly to dissolve the sticky ink in that area. Place some paper towels under the print head area as you trickle in the alcoholl and allow it to drip into those towels. Then allow some time to dry.
The cartridges and those port areas can dry out or become very tacky.
Feb 26, 2008 | Lexmark Z715 InkJet Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
Canon Pixma MX922 Logo
440 people viewed this question
Clive
Clive
old marine
old marine
