Washer will not drain
I have a Kenmore stacked washer and dryer, it will spin but will not pump water. Replaced the pump, but still will not pump. Can you help me?
  • 1 more comment
  • jdonm Nov 21, 2007
    Hose is not plugged. Has electric pump, replaced pump still will not pump. Washer works fine other than it won't pump water.
  • tobidh Sep 29, 2008
    water will not drain, can't figure out how to get to pump and drain hose
  • Anonymous Mar 17, 2014
    kenmore wont drain wont or spin out ,replaced pump
  • 248 Answers
Check for plugged drain hose, or hose from bottom of tub to pump.
Posted on Nov 21, 2007
  • Gerald Griffin
    Gerald Griffin Nov 21, 2007
    Is pump running? If not, do you have 110 volts to it? If not may need timer. You might also want to check wires from pump to timer for breaks.
Kenmore model 970c44102 front load will not drain while spinning
sound's like the water pump is going out I got a old washer and it dose the same
Sep 15, 2012 | Kenmore 98702 Stacked Washer/Dryer
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.99980120 stack washer/dryer won't drain.
Check for a kinked drain hose. Also, if it is an older machine it could have something stuck in the drain pump. The usually culprit is an under wire bra
Mar 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
The spine cycle seem slow need to run more then once
check the tub to pump and pump to drain for blockages of debris,the pump should drain the bulk of the water,then it should spin out the rest unless the belt is that glazed,get to the spin cycle and pull out the washer drain hose out of the house drain stand pipe and see how much force water is while being pumped out while just pumping and not spinning,there should be the water stream the size of the inside of the drain hose and good velocity of water flow to the drain
Mar 13, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
