Question about HP OfficeJet 6210 All-In-One InkJet Printer
Ink Cartidges How do I access ink cartridges to change
  • Tweety46 Nov 20, 2007
    How do I access ink cartridges on HP5510 in order to change
    Guru:
  • 1,463 Answers
Hi is this the printer you have ..
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=311255&lang=en&docname=c00033420#N508.
hope this helps you.
riz.
Posted on Nov 20, 2007
My ink cartridges are stuck far over to left left and i can't move them
Power on the printer and lift the cover used to access the cartidges, the printer should then detect the door open and move the cartridges to a place you can access them. DO NOT FORCE THE CARTIDGES, you will wreck the motor...
Comment if you need more assistance.
Aug 17, 2011 | Office Equipment & Supplies
I dont have any coloured ink cartidges left and need to immediately print some forms in full black will be okay but i cannot change my colours to black as the ink holder stays on the far right of my epson...
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
Mar 11, 2011 | Epson PRINTER, 4800 PORTRAIT EDITION...
Replaced all ink cartridges with epsom cartridges. Printer shows ink incompativble- replaced with identical cartidges and printer wont print
the inks u had replaced might not be the compatible with ur printer you need to change another inks which are compatible only
Jan 26, 2011 | Office Equipment & Supplies
Leaking ink out of bottom right corner?
Depending on the price you paid and how old the printer is, it may be time to get a new one, or it may just be a faulty ink cartridge, especially if you have tried to use a cartridge refill kit.
Try to take both ink cartidges out and clean up around the tray, if upon inspection of the cartidges, you see ink out side, replace em and see if it occurs again with new cartridges.
Cheers,
Jul 07, 2009 | HP PhotoSmart Pro B9180gp - - colour -...
Epson RX580 can't change ink cartridge
well..sounds like your new print cartridges are not too compatible..I recommend you get the right ones
Aug 19, 2008 | Epson Stylus RX580 InkJet Photo Printer
Canon MP170 printer
I HAD THE SAME PROBLEM WITH THIS SAME PRINTER THE ANSWER IS THE INK OVER FLOW SPONGE IN SIDE THE PRINTER IS MOST LIKELY FULL NEED TO BE CLEANED OUT
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Apr 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
Ink cartridge
followed the recommended procedure for changing ink cartridge,however although cartridge moved backwards and forwards it never stopped in the position to change it but remained under the housing on the right side of the unit
Nov 02, 2007 | Epson Stylus C40UX InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
