Question about Microwave Ovens
MICROWAVE WONT HEAT
Hi, every function on my microwave seems to work alright, but the microwave wont heat anything. I replaced the diode. The magnetron passes the continuity test, however, it makes a rattle sound when the microwave starts to run, and the microwave still wont heat. What could be the problem? Is it possible for the magnetron to still pass the continuity test, but not be able to produce the necessary heat? Could it be the capacitor and how would I check it to verify without having to take it out and replace it. By the way, I found one fuse, and it too passed the continuity test. Are there any more fuses?It's a whirlpool model- MH1150XMB-0, Serial #TR R 23 42972,
CAN ANYONE HELP PLEASE?????
    Problem Solver:
  • 11 Answers
The lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at chattarbox24_7@yahoo.com
Posted on Jul 21, 2009
Why microwave does not heat anymore
Well, we are looking at a bad magnetron, cracked high voltage diode, or a shorted high volage capacitor. I would suggest replacing the microwave oven because the expence involved to have it serviced.
Mar 29, 2012 | GE Microwave Ovens
Everything works OK but will not heat anything
Look at magnatron for holes, diode, and HVTransformer..Depending on age of microwave you may need a new one.
Jun 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung smv9165 microwave setting wont heat anything up,seems to power up,table turns vent kicks on ,but food is still cold ,convection setting works but not microwave setting
Replace the magnetron and diode. The parts place will know what your talking about. But it would easier to buy a new one honestly.
Nov 30, 2009 | Microwave Ovens
GE Spacesaver ii has power, but won't heat
Look for a blown fuse in the high voltage area for the magnetron. Usual problem is a shorted HV diode. It could also be a shorted 'stirrer' bearing (a metal fan-like device mounted near the top or side where the microwaves exit the metal wave guide into the cavity). The bearing is plastic and you can't see the arc path because it is inside the bearing--replace the stirrer. Fairly simple fix, but time consuming.
Aug 17, 2009 | Microwave Ovens
Microwave seems to work but doesn't heat up
HI, when the Magnetron becomes unstable, the microwave will not heat anything. simply replace the Magnetron. This device creates the heating action and it is damaged and not functional at this time.
Jun 01, 2009 | Sharp R-1870 Convection/Microwave Oven
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
Ge spacemaker runs but wont heat
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Wont heat
Jan 15, 2009 | LG LMV1314 Microwave Oven
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Jul 24, 2008 | Goldstar MV-1501 Microwave Oven
Wont heat
If the diode is good (not shorted) then I would suspect the magnetron.
Here are some tests that might help:
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | Amana ACO1860 Microwave Oven
Microwave Ovens Logo
525 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
