Question about Trendware Computers & Internet
TEG-160WS - javascript error in login page of web interface
Hi, there is a javascript error in the login page of the web interface of my TEG-160WS (ver.C1) switch : If you analise "gform.js" (view source in IE and you'll see the reference to this file) you'll notice that there is a missing "}" at the last function declared there. This causes the web browser to display an error dialog and makes login impossible. Nice, isn't it? So much with the management console...
I tried to update (or more likely - refresh) the firmware with the last version downloaded from the TrendNet support site - still the same problem.
Is there anyone who has encountered this problem?
Can it be fixed somehow?
SOURCE: Garmin Nuvi 310 D
You can lift of the grey trim on the front and then hold down the reset button might not work though but its worth a try.
Posted on May 04, 2007
wayneard
  • 1901 Answers
SOURCE: Javascript is enabled but it keeps telling me I need to enable it
On IE, clcik Tools>Manage Add Ons.
Is Shockwave Flash Object enabled? Is the file Flash10a.ocx?
Posted on Oct 23, 2008
dude install google chrome you can download it off google.com its the easiest way to solve your problem!!1 :)
Posted on Dec 17, 2008
XopenX
  • 108 Answers
SOURCE: Password was changed
If you forget the password, press the “Reset” button in the front panel
of the Switch, the current setting includes VLAN, Port Setting… etc.
will be lost and the Switch will restore to the default setting.
Posted on Jan 15, 2009
  • 68 Answers
SOURCE: my downloads stop usually after a few seconds
Sounds like a MTU issue. The "MTU" also means "Maximum Transmission Unit". This has to do with the largest packet that you can send on a particular link. In the old days, routers would break a large packet into fragments when they were about to transmit a packet onto a link with a lower MTU.
But this slows down the router and your connection. So these days, windows sets the "Don't Fragment" flag - and rather than break the packet, the router will respond with an ICMP packet that tells your system to send smaller packets - and your system will send smaller packets and avoid the fragmentation load and slowdown.
Problem is that sometimes the ICMp responses do not get through. Security professionals used to block all ICMP, willy-nilly. ICMP (except perhaps Ping) should never be blocked.
http://www.netheaven.com/pmtu.html is a great discussion of this.
What happens is,
1. You open a connection to site X. You tell them that the largest packet you will take is 1500 because that is the MTU on your wireless net.
2. The packets that are used to open the connection are small packets. Then, when the data starts flowing, large packets are sent. One of the packets is too big. The router between them and you sends the "whoops, too big" packet, and they filter it at their end.
3. They resend the packet and it never gets through. You eventually give up.
The problem is on their end - but let me ask this:
If you connect to the modem via a wire, does it change anything? I honestly don't think it is your problem, but it could be - if this is not the issue.
To diagnose, use this scheme to set your MTU to 576.
http://www.windowsreference.com/windows-2000/how-to-manually-set-the-mtu-size-in-windows-xp-2003-2000-vista/
and then see if you can access these sites. If you can access these sites now, then this is your problem.
I do not know anything about your topology, but if you happen to have a link to you with a reduced MTU (are you running PPPoE? Who is your supplier?) and you can figure out what that MTU is, then by setting the MTU on the wireless link to that number, you will avoid having these sites send you large packets. The ICMP response never gets there but it is never needed.
What I don't get is why a reload would EVER work. The response should either go through or not. Resending the same stream should cause a problem in the same place.
Here is an alternate theory:
Years ago, I had a problem downloading a particular file via DSL. Just one file...out of many hundreds I'd downloaded. And occasionally I had a problem with a bit of web content but who cares? But this was a file and it was a hard failure so I could look at it further.
I had my friend compress the file (which changes the pattern of data in the file), and got a copy of the compressed file. Then I blew up the file and looked in the file with a hex editor and, paid special attention to the hunk that was just past the part where the file had hung.
Well, the ping command on Linux allowed you to send a ping with not only a particular buffer length but a particular payload, and what I discovered was that when I sent a particular packet (that matched the part of the file that failed) I would never get the response.
I called my ISP and explained that I had a ping that would fail when certain data came through but not when other data came through and that I could ping with a packet of a certain length but when I sent a packet with different data and the same length I never got a response.
The only difference was the data part of the packet.
I ended up at the highest tech level and they started tracing things while I ran my ping - and suddenly my link went completely dark for a minute and then started working. They had replaced my link card - on my ADSL link. It was sensitive to the content of the data. The internal indication they got was that the checksum had failed so the packet was dropped, but the hardware was broken and they were miscalculating the checksum, the packet was actually fine when they looked at the dump. (As I recall, 64 bytes of hex 0f0f0f0f0f0f would fail so it was simple to see that what I sent got there, by inspection).
Now, there is a possibility that the link, either the wi-fi at your end or the DSL link hardware is broken and is broken in a way (like mine was) where it is data sensitive. And some data causes it to be likely to toss the packet on the floor, while other data makes it through just fine.
If I was a techie, I would get a copy of a program called Wireshark. This program used to be called ethereal, and it allows you to trace what goes over your IP connection and through your adapter. If you understand IP you might be able to see where the TCP connection stalls and then when you restart it and it goes through, what is in the packet following the stall. If it fails in the same way every time, it might be possible to use something like wget for windows (which see: like http://gnuwin32.sourceforge.net/packages/wget.htm ) and to get a particular file and cause a reliable failure, or a high percentage of failures, and with that in hand to call your ISP.
If you can cause the problem to happen with multiple computers at your end you might be able to get them not to look at your computer.
A trace of a failing wget would be the next thing I would look for. Hope this helps, let us know what happens.
A final theory is that, to stop people from filesharing, the ISP is rolling your IP address every few minutes. By breaking a PPPoE connection and forcing the router to reconnect and always supplying a new IP address, or doing the same sort of thing with a short DHCP timeout and rolling the IP address, they could do a lot to interfere with the popular programs that share large files, like bittorrent and such.
If you happened to be downloading a file when your IP address changed, it would, perforce, cause your download to be interrupted...the ISP could stop sending packets with your old IP address instantly, and, in this case, control-r would have a good chance of working, since well designed web programs use cookies and magic URLs to identify the stream, and not origin IP since so many people mash a bunch of identities into different streams from one IP address.
You could diagnose this by connecting to your router and determining what your exterior IP address is, then, when you get a hang, see if the exterior IP address has changed.
Posted on Jan 08, 2010
What ls a alerts.
hi there.
Alert may refer to any of the following:
1. In JavaScript, an alert is a type of "pop-up" message to users of a script. An alert could be anything from notifying the user of an error to saying a short phrase such as "Hi". A JavaScript alert looks similar to the example shown to the right. This alert can be produced by using the JavaScript code shown below.
type="text/javascript">
window.alert("This is an alert!");
Since the window object is a top-level object in JavaScript (when coding for web browsers), this code can be shortened to alert() rather than window.alert(), as shown in the example below.
While these are often known for their ability to annoy users (for example, the sending of numerous consecutive alerts), they can also be useful for giving the user information such as instructions for fixing errors in a form field. They can also be helpful to JavaScript programmers as a means of debugging a script. By using an alert message to display values, the programmer can determine where things may be going wrong in a script through the process of elimination.
2. In general, an alert box, also called an alert dialog or alert window. It is a small window that pops up providing information to the user and typically includes an OK button, and sometimes a Cancel button.
Error messages and general information are commonly displayed in alert boxes, as it calls attention to itself and makes the user click a button to hide the message. The Windows operating system, along with third-party applications, and web pages are sources for alert boxes.
or go to this link.
What is alerts Google Search
Nov 17, 2017 | Cell Phones
Tip
How to Solve the Javascript Void(0) Problem
Many internet users face this problem when they try clicking a link and see this error code on the status bar of the browser which doesn't allow the link to work. It is actually an error message that occasionally appears in a web browser when you face a problem loading a JavaScript from a webpage. Though this error message pops up on various occasions but the actual reasons could be different for different users, and resolving these problems is necessary by knowing the most possible reasons for this error message.
1- The major cause of this error message is the Popup blocker blocking the JavaScript while stopping the windows which open up as the advertisements on various sites. Resolving this problem involves making changes in the preferences of the popup blocker based on your requirements and thus disabling the popup blocker. One can even download another anti popup software instead or can read the product reviews of popup blockers to assess if they really cause these error messages.
2- The malfunctioning of the web proxy servers (which are used for accessing the various banned websites) can also block the various scripts in the process. This problem can be avoided by not using the proxy server itself or using a proxy server that functions better and do not interfere in the downloading of various scripts. Also check for the compatibility of the proxy server with various web pages and scripts.
An improperly written JavaScript could also lead to this error message. The solution lies in notifying this error to the webmaster who in turn must rewrite the JavaScript.
3- The JavaScript might be disabled in your browsers, and this needs to be enabled. To enable this in IE, go to scripting tab of the security option in the Tools menu under the internet options; and to enable this in Firefox, go to Tools menu and enable the JavaScript option in Web features.
4- Web browser implementation of JavaScript might also be broken in some cases, and this requires the switching or simply the up gradation of your web browser.
There is this simple way where you can really avoid "javascript:void(0)" error message at the first instance because we know that this "javascript:void(0)" can cause certain browsers to really present your web pages in unusual ways, and since the "javascript:void(0)" statement is often occurred when a link has no URL attached to it, and the browser doesn't understand how to react and returns the error message. So for this, instead use the "return false;" statement to let the browser not to look for the URL. Try opening the document in any text editor; Locate the "javascript:void(0)" references within the document, Replace the links with the (#) symbol with the syntax ".", Add the "return false" declaration to the statement that would make the whole link reference to appear as a Link. Replace the "callFunction()" with your function name; Save and close the file finally.
on Jan 12, 2010 | Computers & Internet
I want my old version of yahoomail back. The "new" version is no good. How can I do this?
Yahoo has specifically disabled the "return to classic mail" link on the New Mail interface. This is specifically to discourage people from going back, as the old mail interface will eventually be removed completely, and all users will be forced onto the new one.
Here is the explanation page from Yahoo Help:
http://help.yahoo.com/l/us/yahoo/mail/ymail/migrating/fromclassic/mltamnoswitch.html
However there is a possible workaround to get back to Yahoo old mail. Open your browser (Firefox 5) and go to Tool-->Options-->Content, and UNcheck the box marked "Enable Javascript." This will disable Javascript from running in that browser. Then try to log into your Yahoo mail account. You should get an error message from Yahoo that your Javascript is disabled- ignore that, and continue to log in to your Mail account. Supposedly, you will be given the option to return to the old mail interface. If that occurs, go ahead and log in. You should then go back and re-enable Javascript, or your mail, and many other websites, will not function correctly.
Aug 03, 2011 | Yahoo Mail
I want my old Yahoo back
Let us know if this works.
Jul 31, 2011 | Yahoo Mail
I am getting javascript errors when I open web pages using my ps3
Your javascript errors have nothing to do with your router settings. Change the security settings on the ps3 to allow javascript. Also not all javascript will run on your ps3 browser.
Mar 05, 2011 | Computers & Internet
How can i solve "javascript:void(0)? in Chrome
javascript:void(0) is an error message that occasionally appears in a web browser when there is a problem loading a JavaScript from a web page.
Here are some Possible Resolutions you can try:
Disable your popup blocker
Disable your web proxy, if you have any.
Enable JavaScript
Switch web browsers or upgrade your web browser
It is also possible that the website you are viewing has nn improperly written JavaScript. There's no way we can resolve that on our end.
Nov 29, 2010 | Google Chrome
How to enable javascript in nokia 6030
  1. Open the Nokia web browser.
  2. Navigate to a site that uses Javascript applications. You may see the error message informing you that Java is not enabled, and the website components won't work properly.
  3. Go to "Options," "General," then "Java/ECMA Script."
  4. Choose "Enable" to activate Javascript.
  5. Refresh the web page. If the Java elements of the page work, then you have been able to activate Javascript on your phone. Otherwise, troubleshoot the problem by turning the phone off and on, or checking for any web browser software updates. You may also want to check another Java based webpage to ensure that the problem is not with the page you are trying to access.
Oct 04, 2010 | Nokia 6030 Cellular Phone
Hi can you please help me where can i find the login page for u.s.robotics 5462 sos i can put the wep key thxs
  • Heres the support site for that Model http://www.usr.com/support/product-template.asp?prod=5462
  • Direct link to the PDF manual http://www.usr.com/support/5462/5462-files/5462-ug.pdf
  • Page7 describes how to log into the router Launch a Web browser. In the location or address line of your Web browser, type http://192.168.2.1 to access the Web User Interface.
  • After the connection is established, you will see the Web User Interface.
  • The default password is admin. Click Login.
On the lefthand sie - you should see wireless Page 31 - sub menu - security - to enable your wireless security, type and passcode
Mar 22, 2010 | Computers & Internet
IE 7 will not respond to the javascript resize javascript:window.resizeTo(1024,768) I have enabled scripting in Intenet Options and restarted IE. I even created a web page that has the javascript for...
post the javascript code and I will have a go at seeing why it is not working - it may be that IE 7 needs slightly different code but when I see or get the code you have I can look into it more
Jun 04, 2009 | Dell Studio 17 Laptop
How to turn off the router's firewall
1. Insert the Product CD into your CD-ROM drive. The CD will run automatically.
From the Utilities section, select to install the uConfig utility to your hard disk.
2. When the utility has been installed, double-click on the uConfig icon. The
following screen will appear, click on the Yes button to proceed.
3. Select the router from the products list and click on the Open Web button. To
retrieve and display the latest device(s) in the list, click on the Refresh button.
4. Do not exit the uConfig program while accessing to the web-based interface.
This will disconnect you from the device. Click on the OK button to proceed.
5. At the login page, press the LOGIN! button to enter the configuration page. The
default password is “password”.
6. For the first time login, you will be prompted to select your time zone setting first
before accessing the router’s main web page. Take note that during the next
and subsequent logins, you will not see the System Time Setting page again.
7. You will then reach the web page of your router’s web-based interface.
8. Under the SECURITY CONFIGURATION command menu, click on Firewall
Configuration.
Oct 22, 2008 | Compex Computers & Internet
Computers & Internet Logo
120 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
