Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Seems to cool ok, but every few minutes a loud buzzing comes from near or behind the compressor. It stays on about 5-10 seconds and then shuts off
    President:
  • Frigidaire Master
  • 1,922 Answers
Sounds like the compressor contactor is getting weak
Posted on Jul 28, 2009
Every 3-4 minutes the a very loud buzzing sound occurs for ~20 seconds. It sounds like it is coming from the compressor area. The fridge and freezer are both working well.
It sounds like the starting components on your compressor are bad. the buzzing is your compressor trying to start and then shutting down on its overload. You will need to replace your starting components on the side of the compressor (start relay and overload) which will usually come in a kit together. Good luck _MJ_
Apr 23, 2010 | Maytag MZD2766GES Side by Side...
My TV has developed a loud buzzing sound. Tha lamp seems to work ok, and the sound seems to be emanating from the fan, which is working. Fan or color wheel? The picture comes on, but seems to deteriorate...
Color wheel is bad call Encompass Parts or visit their website and if they dont have one in stock at least you will know what your Part number is ! then you can Look it up on E-Bay I have found parts there cheaper 1-800-638-3328 or try UED 1-800-648-6657
Nov 17, 2009 | Televison & Video
Refigerator not cooling
I need you to go over a few things and check so we can eliminate the problem. When ready let me kow so we can check the defrost system. Thanks, Sea Breeze
Oct 21, 2009 | Maytag MFD2560HES Bottom Freezer French...
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Frigidaire side by side
The compressor sounds like the start device went bad. When that happens there is the "click" during trying to start, but since it can't the compressor overheats in time and then the thermal overload opens to protect it from overheating. Take the back lower panel off the refer and see if the compressor is really hot to the touch. If you have a little white colored box on the left side of the compressor pull it off and shake it... if it rattles and debris falls out you know it's bad. There is a kit that replaces it and it's real easy to install yourself. If you have a compressor that has a little blue indian head symbol on it however... your compressor is toast. Once they overheat they're done. If you have any other brand name you should be OK with a simple start device change out.
Jan 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Oct 22, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
129 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
