Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet Sport front load...won't spin
Glass bead stuck between drum and floor of machine and will not allow it to spin. I can manually turn the drum about 7 inches but gets jammed when the bead gets into a certain position. I took off the bottom panel but cannot access where the bead is from there due to the rubber gasket. Any ideas? How do you remove the front panel..not the bottom front panel. I really can't afford a service call. Thank you!
None
Posted on Jan 17, 2011
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET SPORT FRT LODER WASHER VIBRATES VERY BAD
Might be a simple fix. First, make sure your machine is sitting level (or pretty close to level) on the floor. Next, using a Torx bit (probably, that's what my 9250 had), unscrew the screws holding on the front access panel. When you look inside, you'll notice several shocks (usually 4) that stabilize the drum as it turns and spins. Make sure they are all intact and mounted to the drum (they have a tendancy, especially after having been run in an excessively vibrating state, to dismount from the drum). If the mounting pin is intact, stretch the shock to reinsert it into the slot on the bracket mounted to the drum, and turn to lock it into place. If the mounting pin is broken, you'll need to order another (probably the entire shock, actually) to repair it. Also, be sure that you are not overstuffing your washer, as overloading will also cause excessive vibration. Hope this helps!
Dec 07, 2012 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
My Whirlpool duet sport makes a terrible noise during spin cycle like drum hitting something or belt slipping. There are no error codes or smell of burning belt. HELP!!
the drum bearings are shot,you need to get them replaced,if the drum is actually hitting the sides if the tub this could be a broken spider thats on the rear of the inner drum that holds the drum on if this comes loose it can cause serious personal injury
May 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport--won't completely spin out, leaves water in the tub. I cleaned out the drain filter, it kind of works for 1 load then goes back to not spinning out completely.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer won't spin
dduet front load fills--no wash drains what's wrong a belt?
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Front Load - Spin Cycle Noise
Had one do this. Turn machine around look at bottom two corners. Machine comes with metal rods to stabilize drum during shipping. Installer forgot to pull those out on mine. Once I removed them noise quit.
Jul 07, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
360 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
